Toilet Trouble - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-24-2010, 06:20 PM   #1
Toilet Trouble
I have a toilet that won't fill up. I can turn the water line off come back a few minutes later turn it on and it will fill up, however it slowly disapears. It also sounds like it's running when I leave the water on. I have little to no experience with toilets, please help!
raven4209 is offline   Reply With Quote
Old 06-24-2010, 07:59 PM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome. Sounds like it could have a leak or a bad flapper. What is under the toilet? a crawl space? basement?
I'd be looking under there for signs of water. Could just need a new wax ring. Is the toilet loose?
DM
Old 06-24-2010, 08:44 PM   #3
Owner
LateralConcepts's Avatar
Could also be something more serious.
Which toilet is it? (i.e. main floor, basement, upstairs)
Are you on sewer or septic?
Do you have a history of sewer or septic problems?
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 06-24-2010, 10:19 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Sounds like you might have sediment in the fill valve. When you turn off the water, the sediment falls to the bottom of the fill valve. When you turn the water back on, it is slowly blown back up to the top where it clogs the rubber diaphragm.
To test this theory :
Turn off angle stop valve under toilet.
Disconnect supply on toilet tank side.
Using a small bucket, put the open end of the supply in it and crack the valve to see what kind of water flow you get from the supply.
Good flow = bad fill valve
Bad flow = problem with either supply, angle stop, or piping to the stop. Diagnose further at this point.
Journeyman Plumber
Old 06-24-2010, 10:29 PM   #5
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
If I understand your problem right, you simply need a new flapper. The flapper at the bottom of the tank is not making a good seal, so the water is running out of the tank and down into the toilet (then down the drain). They are very cheap and available at any hardware store.
Sometimes they come in different shapes, so it helps to see what your existing one looks like before you go to the store. Examples:
http://www.google.com/products?q=toi...ed=0CEMQrQQwAA
hyunelan2 is online now   Reply With Quote
Old 06-24-2010, 10:50 PM   #6
Doing it myself
Alan's Avatar
I can't believe we have so many different responses to a simple toilet question. Something is wrong here. Maybe elaborate on your problem a little more please, because we all seem to be assuming something here.
Journeyman Plumber
Old 06-24-2010, 11:27 PM   #7
Owner
If you're losing water from the bowl it could indicate a soft blockage in your building sewer (main line from the house to the street or house to the septic tank) Sludge buildup due to a belly (low spot) in the line can lead to a soft blockage, suddenly clears itself, then will suck the toilet dry. Clearing the line would then require a jetter.
If it's only happened once, it could be that the city came by with a jetter to clear the city main and it sucked it dry.
If the water is being diminished from the tank then it's a simple fix. Most likely just the "water control diaphragm" aka flapper.
Lateral
(208) 818-8241
Old 06-25-2010, 06:21 AM   #8
My vote goes to the tank not staying filled and the flapper valve is either damaged or not seating correctly. There is no physical way a toilet bowl can slowly drain just sitting there unless there is a hole or crack in the china
The Engineer is offline   Reply With Quote
Old 06-25-2010, 07:55 AM   #9
Owner
Engineer - You're probably right with your vote for a flapper. With all due respect however, I think you're wrong about the bowl draining. As I mentioned above a soft greasy or sludgy blockage in the line is also plausible and can create a vacuum sucking the water out of the bowl when it clears itself, or likewise a city jetter in the main going by the lateral.
Lateral
(208) 818-8241
Old 06-25-2010, 08:28 AM   #10
Hi Lateral Concepts, What you describe is possible if the toilet is not properly vented and/or the blockage is close to the toilet outlet. However, when the toilet is flushed and after the water goes down the drain, the tank starts to re-fill and during this time a small percentage of water during the fill cycle is redirected to the bowl to fill and top off the trap. During these 20-30 seconds the waste water has already passed by the blockage and any vacuum effect would pull water out of the bowl in the early stages of the fill cycle. After the tank is filled andthe valve shuts off, the earlier flush water is already on its way out of the house. If the blockage is further down the line and the toilet is not vented, then yes what you describe is possible, but with a properly vented toilet, the vacuum effect will pull in air through the vent instead of water out of the trap. Hope this makes sense.
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 10:14 AM
closet flange trouble for antique toilet diyb Plumbing 4 05-20-2009 08:07 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
