Toilet Too Close To The Wall...cover Won't Fit - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-12-2012, 06:37 PM   #1
Toilet too close to the wall...cover won't fit
The toilet in our 1854 home is too close to the wall. The lid won't fit on the tank. The previous owners simply gouged a hole in the wall that the lid slid into. I thought I would be able to replace old flange with an offset flange but it looks like I have cast iron flange and don't know how to get it off. Also, would an offset flange work? Do they make toilets that are smaller - maybe a new toilet would fit better?
Thanks Jennifer
Mrscoyle is offline   Reply With Quote
Old 05-12-2012, 07:03 PM   #2
Hi Jennifer,
What measurement do you get when you measure from the finished wall to the middle of the bolts that hold down the toilet? If it's 12" then you're in luck as they make them with a 10" rough-in. Otherwise, do you have access to the drainage below the toilet? Do you have any pics that you could share so we could see your set-up?
VIPlumber is offline   Reply With Quote
Old 05-12-2012, 07:13 PM   #3
toilet too close to wall.... rough in ...sheesh!
It looks like my rough in is only about 9.75. Drats. I am beginning to suspect they put new sheet rock on top of old wall and that may account for some of my problem. Most of the house is horse hair plaster but this bathroom has suspiciously newer walls...not to mention the sheet rock behind the toilet was not really set in well.
This toilet is on the 2nd floor...I don't think anything can be done from below.
this is starting to feel beyond my capabilities. Arg.
I have luncheon for a bunch of ladies soon and I really hoped the "view" would be better by then. The lid off the tank all the time is unpleasant. But the cats appreciate it.
I don't have pics yet. But will soon!
J
Tags
flange , tank lid , toilet
Toilet too close to tub mrlong` Plumbing 20 04-21-2011 12:54 PM
Bathroom - Toilet too close to wall? No vent?! mlenihan Plumbing 5 03-27-2011 08:20 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
wall mount toilet jjrbus Plumbing 8 11-12-2009 02:07 PM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 03:53 AM
