Toilet Time - With Video - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-15-2011, 08:19 PM   #16
see if these instructions will help remove your flush valve. the toilet is similar but cant tell if its the same flush valve. do the other toilets that work ok have the same flapper as the one that you are having the problem with?
i would adjust the water level in the tank lower and see what happens. it looks like its a little high. its almost to the holes in the back.
http://dallas.eljer.com/Products/Toi...tion/1pc35.pdf
Old 08-16-2011, 10:50 AM   #17
Rewards Points: 590
Thanks for the PDF. The toilet actually flushes better with the water level that high. When you set the water level to the line, the water in the bowl doesn't flush well at all. I am going to take some needle nose pliers and wedge them down there and use a long screwdriver to twist it out and reseat the flush valve square to see if that helps.
noone is offline   Reply With Quote
Old 08-16-2011, 12:52 PM   #18
Homerepairguy's Avatar
Rewards Points: 998
If you decide to rebuild the parts in the tank, maybe try this first. Use a metal cutting sissors/snips and cut out a vertical section of the plastic clyinder. This will negate use of the plastic clyinder.
Then adjust the float level so the flapper drops down and seals just as the water in the bowl empties with the whoosh sound. This should allow the minimum amount of water flushed and still allow a complete flush.
HRG
Homerepairguy is offline   Reply With Quote
Toilet Problems akim1220 Plumbing 6 02-25-2014 05:59 PM
Toilet won't sit all the way on floor bsmith6356 Plumbing 23 02-03-2013 08:29 AM
how do i tell what size "rough in" my current toilet is? liverlipsyyz Plumbing 12 07-20-2012 01:39 PM
Toilet has me bumfuzzled........ TyWebb Plumbing 4 03-17-2010 08:14 AM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 10:14 AM
