Old 12-02-2012, 06:13 PM   #1
Toilet on tile or tile around toilet?
Hey everyone,
Redid my bathroom floor, the flange of the toilet (cast iron i think) I was only able to wiggle high enough for it to sit on top of the hardiback. The tile will then go on top of the hardiback.. So my question is do I put the tile on first which will create a quarter inch gap from the flange or install the toilet and tile around it?
In essence, can the wax ring account for the gap between the flange and the actual toilet?
vexious is offline   Reply With Quote
Old 12-02-2012, 06:36 PM   #2
Yes it can, all finshed flooring always go under the toilet.
Old 12-02-2012, 06:47 PM   #3
Ok thanks, I was just confused because in all photots and videos I see the round metal/plastic ring (flange?) goes then on top of the tile as well?
Old 12-02-2012, 07:39 PM   #4
Do it the #1 way as the diagram below depicts. Bottom of the closet flange rests on the finished floor.
hammerlane is offline   Reply With Quote
Old 12-02-2012, 07:42 PM   #5
I vote for:
Old 12-02-2012, 07:45 PM   #6
Super Moderator
Screw that flange to your backer board---then tile around it---when the time comes to set the toilet---use a wax extender ring and the extra long bolts that come with it---if the flange is to deep for that---a second ,all wax ring could be used or a plastic flange extender---
That works well----
Old 12-02-2012, 07:51 PM   #7
Super Moderator
There is a never ending debate over this question----after you have set a couple hundred toilets--you will develop a preferred method---
I like the tile around the flange---Both methods work---
as long as you don't use a 3" inside mounted flange --or a thick PVC flange or have an Italian toilet---then that flange better be tiled in or the flange may well hit the bottom of the toilet.
jaydevries (12-02-2012)
Old 12-02-2012, 07:52 PM   #8
Agree with that.
The Following User Says Thank You to hammerlane For This Useful Post:
oh'mike (12-02-2012)
Attach toilet flange to plywood subfloor, or on top of tile? jmai14 Plumbing 2 10-27-2012 07:37 AM
Tile Will Make Toilet Flange Lower crayola110 Plumbing 7 09-24-2012 03:31 PM
Tile around Toilet flange. Tile will be at Higher Level than Flange? crayola110 Tiling, ceramics, marble 0 09-19-2012 07:07 PM
New Tile in Toilet Area JHensley Flooring 5 09-23-2011 11:16 AM
toilet install over new tile floor dbrew Plumbing 6 02-21-2007 12:17 PM
