Toilet Tank Won't Refill After Flushed - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-03-2011, 10:34 PM   #1
After I flush the toilet the bowl and the tank don't refill. I took the lid off the tank and when I lift the "floater" up a little everything starts to refill. It isn't the ball kind of floater. What could be wrong. It is like it doesn't know it is supposed to fill until I lift up on the floater. Any help is appericated. I know nothing about toilets and need to fix this quick as I will have a house full Saturday!
mander is offline   Reply With Quote
Old 05-03-2011, 10:44 PM   #2
Rewards Points: 352
put in a new fill valve. A fluidmaster 400a is available at any plumbing supply place.
plumberinlaw is offline   Reply With Quote
Old 05-03-2011, 11:59 PM   #3
the float is sticking; if it's more than a couple of years old, spend the $10 and get a new flush valve. It takes like ten minutes to install.
Robo_geek is offline   Reply With Quote
Old 05-04-2011, 04:19 AM   #4
Lightfoot's Avatar
Rewards Points: 272
I agree
If you already have a fluidmaster in place (and it's acting this way), just replace the rubber seal/diaphragm (less than 2 bucks) and it's good as new.
Lightfoot is offline   Reply With Quote
Old 05-04-2011, 12:15 PM   #5
Rewards Points: 1,442
The fill valve and float may have an anti-flood feature that stops the fill depending on how slowly the float descended. See if there are additional parts such as a tether that is supposed to be attached to the flush handle arm that pulls the flapper up and distinguish a flush from a tank bolt leak.
Old 05-04-2011, 09:53 PM   #6
Thanks everyone I bought a fluidmaster and should install it tomorrow.
Old 12-14-2012, 10:08 AM   #7
Originally Posted by Lightfoot View Post
I agree
I'm having the same problem as mander. After flushing the toilet the tank occasionally won't fill unless I jostle the fill valve or turn the water off/on at the wall.
I've replaced the fill valve twice but the problem persists. Once I used a fluidmaster but this didn't solve the problem.
The water pressure is very strong in the tank. I'm curious if this could be causing the issue.
I'd appreciate any suggestions
Fletch24 is offline   Reply With Quote
Old 12-14-2012, 01:31 PM   #8
DIY staff
Rewards Points: 7,174
It's very easy to install the valve so that the float rubs against the side of the tank---rotate the valve so there is plenty of clearance---that is the cause 9 times out of 10
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Leaky Toilet Tank Valve Tuckahoe Sparkplug Plumbing 4 07-10-2010 07:21 AM
Toilet Tank Movement dschucky Plumbing 2 05-04-2010 01:41 PM
Bubbles In Toilet Tank JCNimmo Plumbing 2 01-29-2010 09:11 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
