-   -   Toilet Tank Will Not Refill (http://www.diychatroom.com/f7/toilet-tank-will-not-refill-148666/)
Laticha 06-30-2012 01:18 AM
Hello Ladies and Gents,
I'm experiencing problems with my two toilets in my house. It's been raining for a week and yesterday the water supply from the outside tank discontinued (I use grey water for my toilets). Every time I try to turn the pressure pump outside back on, it causes the main power supply for the house to turn off. Also, when I do turn it on it doesn't fill the toilet tanks inside.
I've had a similar issue with the toilets before, where I have had the pressure pump removed and replaced. Is there a cheaper option that can fix this issue?
Thank-you for you help!
wctekkk 06-30-2012 02:14 PM
sounds like your pump has a elect short or in the wiring. I don't know if it's cheaper you could hook up the toilets to potable water
