Toilet Tank Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-05-2013, 07:50 PM   #16
I broke the tank on my 1950's yellow toilet and figured no way on earth I could find a replacement and I could not find a new toilet to match sink/tub color (that funny yellow).
But I found the identical toilet on ebay and the pickup was a short driving distance from my house.
Maybe ebay could help? Just a thought. Good luck!
agoodboy is offline   Reply With Quote
Old 04-06-2013, 06:03 PM   #17
Rewards Points: 1,832
I spoke with a plumber and he can order a replacement Gerber tank from the supply house. There several newer designs that have the bolts 6 and a half inches apart that will fit the toilet.
Jump-start is offline   Reply With Quote
The Following User Says Thank You to Jump-start For This Useful Post:
ben's plumbing (04-06-2013)
Old 04-07-2013, 08:13 AM   #18
Rewards Points: 33
But, will the new tank be a 1.6 flush? As you mentioned above, your 1986 tank probably uses something like 3.5 gallons per flush. If you go to a 1.6, it probably won't work properly. And no, I don't think most new tanks can be modified to flush 3.5 gallons.
I say replace the entire toilet.
stephen9666 is offline   Reply With Quote
toilet tank replacement JRH91709 Plumbing 1 03-23-2011 03:30 PM
whistling toilet tank fill problem Need Advice Plumbing 6 01-16-2011 08:13 PM
Leaky Toilet Tank Valve Tuckahoe Sparkplug Plumbing 4 07-10-2010 06:21 AM
Bubbles In Toilet Tank JCNimmo Plumbing 2 01-29-2010 08:11 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
