Toilet Tank Is Not Filling - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-20-2010, 08:08 AM   #1
Toilet tank is not filling
I have Brigg's toilet tank. All of a sudden I notice the water is not filling the tank even when the lever is activated. Any suggestion?
arun46032 is offline   Reply With Quote
Old 02-20-2010, 08:27 AM   #2
Rewards Points: 40
Frozen water line?Also try moving your post to Plumbing section.
daveb1 is offline   Reply With Quote
Old 02-21-2010, 12:50 PM   #3
Rewards Points: 5,336
There are a few things that could cause the tank to stay dry.
The water is shut off to the toilet.
The washer at the shutoff valve could have broken and clogged the valve or pipe.
The flushing mechanism inside the toilet could be broken.
If you're in a cold climate and the pipes are in an exterior wall( as previously posted) the supply pipe could be frozen.
Do you have a basement?
Where do you live?
Any other issues with water pressure?
Ron
Old 02-21-2010, 09:31 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Sometimes the supply tube gets clogged. Turn off the water to the toilet, remove the supply and see if you can blow through it. If you can, then try cracking the valve open just a touch to see if water will come out (keep a towel handy).
If water comes out of the valve, then the only other problem is the fill valve. You can try to fix it but you'll have to take it out anyway. Might as well put in a new fluidmaster 400A, and adjust as needed.
Journeyman Plumber
toilet tank fills even after wall valve shut off msmitymite Plumbing 9 09-11-2016 09:21 AM
Bubbles In Toilet Tank JCNimmo Plumbing 2 01-29-2010 08:11 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Leaking from toilet tank? tripflex Plumbing 4 09-29-2009 11:29 AM
Setting a Toilet tank against a tiled wall jibanez Plumbing 3 01-17-2009 07:54 AM
