Toilet Tank Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-12-2011, 04:56 PM   #16
Rewards Points: 1,216
Never over tighten any hardware on toilets just put them together a little snug then turn the water on , if it leaks just tighten very little till it stops.
Most people that install their own toilets over tighten everything.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
RMCarner (10-12-2011)
Old 10-13-2011, 07:04 PM   #17
union plumber.
leaking bolt hole !
try removing the bolt & rubber washer & use a wax ring or the part of & rub it around the china in the area of the leak then put some on the bolt & washer then reinstall. i have had this happen to me as well good luck.
local370 is offline   Reply With Quote
The Following User Says Thank You to local370 For This Useful Post:
RMCarner (10-13-2011)
Old 10-13-2011, 07:07 PM   #18
Rewards Points: 77
How's about plumbers putty? Leak is not coming from both bolts.
RMCarner is offline   Reply With Quote
toilet tank fills even after wall valve shut off msmitymite Plumbing 9 09-11-2016 09:21 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Newer type toilet either leaking water or air in tank drpcken Plumbing 3 04-15-2010 02:30 PM
Leaking Toilet??? WBNC Plumbing 5 10-09-2009 12:51 PM
Leaking pipe under toilet aprildawn Plumbing 4 01-21-2007 04:32 PM
