Toilet Tank Intermittently Would Not Fill - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-05-2011, 07:32 PM   #1
toilet tank intermittently would not fill
My toilet is. flushing fine but sometimes tank will not refill with water after flushing. I have to turn off the water valve and turn it back on before tank will refill again. This happens a few times everyday and I cant figure out a permanent fix. Pls help!
handyman_wanabe is offline   Reply With Quote
Old 07-05-2011, 08:04 PM   #2
Rewards Points: 150
Put in a new fill valve in tank.
josall is offline   Reply With Quote
Old 07-05-2011, 08:05 PM   #3
DIY staff
Rewards Points: 7,174
Change the flush valve--the're $10.00 or less and quite simple to change.
Old 07-05-2011, 08:36 PM   #4
Lightfoot's Avatar
Rewards Points: 272
if it's a fluidmaster just replace the small rubber seal/diaphragm. The rubber hardens after a few years. It's about a two minute job, no tools required. The last one i bought was $1.35 a couple of weeks ago. It's just about the only thing that ever goes bad with a fluidmaster. They are the best IMO
Lightfoot is offline   Reply With Quote
Old 07-07-2011, 08:14 PM   #5
thanks!!
thanks for all the replies. really appreciate it. i changed the valve and it's working so far :-)
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Carbon particles in toilet tank BobMac Plumbing 0 11-21-2010 01:58 PM
Leaky Toilet Tank Valve Tuckahoe Sparkplug Plumbing 4 07-10-2010 06:21 AM
Toilet Tank Movement dschucky Plumbing 2 05-04-2010 12:41 PM
Slow toilet tank fill even with NEW fill valve? Zilla Plumbing 8 08-10-2009 09:37 PM
