#1 |
Toilet Tank Help
Can someone please help me with getting these off the tank. The two smaller parts just keep turning, and the bigger part is just stuck on there. The toiet is from 1957.
#2 |
Toilet Tank Help
You are butting a wide blade screw driver on the slot inside the tank to keep the screw from turning right?
#4 |
Toilet Tank Help
It's going to take two people to do this.
Since the bolts been there that long I'd be using my impact screw gun with an adaptor so it will fit a socket by now. If that did not work I'd use my sawsall. |
#5 |
Toilet Tank Help |
| The Following User Says Thank You to ben's plumbing For This Useful Post: | plummen (05-01-2012) |
#6 |
Toilet Tank Help
i would use a multi tool "fein, ridgid, bosch,or milwaukee" less aggressive vs sawzall and cut nut so you can put screwdriver in to cut and turn which will spread nut then slide off of threads
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are 1 poop needs to flow down hill. 2 hot on left cold on right 3 i get a pay check on Mondays 4 do not chew finger nails at or after work. |
#7 |
I=E/R
Toilet Tank Help |
#8 |
Toilet Tank Help |
| Display Modes | |
| Septic tank missing T and badly angled main line? | denemante | Plumbing | 3 | 11-22-2011 10:29 AM |
| Toilet Tank Leaking | RMCarner | Plumbing | 17 | 10-13-2011 08:07 PM |
| drip drip drip from toilet tank | n2learning | Plumbing | 8 | 02-27-2011 03:15 PM |
| whistling toilet tank fill problem | Need Advice | Plumbing | 6 | 01-16-2011 09:13 PM |
| Upstairs toilet pipe noise | bliss | Plumbing | 8 | 01-10-2008 08:55 AM |
