-   -   Toilet Tank Help (http://www.diychatroom.com/f7/toilet-tank-help-142169/)
amd250 04-30-2012 06:59 PM
Toilet Tank Help
2 Attachment(s)
Can someone please help me with getting these off the tank. The two smaller parts just keep turning, and the bigger part is just stuck on there. The toiet is from 1957.
joecaption 04-30-2012 07:03 PM
You are butting a wide blade screw driver on the slot inside the tank to keep the screw from turning right?
amd250 04-30-2012 07:05 PM
trying to.
joecaption 04-30-2012 07:39 PM
It's going to take two people to do this.
Since the bolts been there that long I'd be using my impact screw gun with an adaptor so it will fit a socket by now. If that did not work I'd use my sawsall.
ben's plumbing 04-30-2012 08:45 PM
Originally Posted by amd250 (Post 911264)
trying to.
I would not use the impact wrench that china is brittle..just me maybe chicken.....use the sawazll it is the better choice even at that be careful...:yes:
jaydevries 04-30-2012 09:03 PM
i would use a multi tool "fein, ridgid, bosch,or milwaukee" less aggressive vs sawzall and cut nut so you can put screwdriver in to cut and turn which will spread nut then slide off of threads
a7ecorsair 04-30-2012 09:39 PM
I doubt it is a collectors edition, could be time for a new one:yes:
COLDIRON 05-01-2012 06:07 AM
I second that:thumbsup::thumbsup::thumbsup:
Evstarr 05-01-2012 08:49 AM
lmao! That old seems likely to crack at the application of anything more powerful than a Dremel to me.
