Toilet Tank Cleaning - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-09-2009, 08:19 AM   #1
Toilet tank cleaning
Just moved into a new home and the toilet tanks are all lined with a black film; I'm going to change out the insides but what do I use to clean the inside of the tank?
dknarnd is offline   Reply With Quote
Old 08-09-2009, 02:36 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Rubber gloves and a little bleach or bleach cleanser ought to do it.
Mike
Mike Swearingen is offline   Reply With Quote
Old 08-10-2009, 07:54 AM   #3
RippySkippy's Avatar
The black could be from the deteriorating rubber componet. While your in there and have the tank clean...closely inspect the flapper, rubber washers that hold the tank to the base, and fill valve replacing any/all that need it. I doubt you'll even need any bleach...just a rag and clean water. I assume you're on city water? If not...I wouldn't want a large volume of bleach going into the septic system.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Setting a Toilet tank against a tiled wall jibanez Plumbing 3 01-17-2009 07:54 AM
sewer backup and stench jayhill Plumbing 12 08-13-2008 11:06 PM
toilet tank leaking econdave Plumbing 12 07-07-2008 07:17 AM
toilet tank burst BillD Plumbing 4 06-29-2008 11:49 PM
