Old 11-25-2010, 07:39 PM   #1
Toilet tank bolts
Someone has tried to tighten`the bolts that hold the tank to the toilet. The wingnut and bolt is corroded and they tore the slot up on the bolt head. How do I hold the bolt to get the wingnut off?
wilard428 is offline   Reply With Quote
Old 11-25-2010, 07:55 PM   #2
Toilet tank bolts
sound's like you are going to take a hack saw blade and make a new slot. These are brass so shouldn't be to hard to do . If you have a dremel tool with a cutter that would be easy any thing to make a new slot in the bolt
Now when installing the new one's don't tighten to tight or you will brake the tank
del schisler is offline   Reply With Quote
The Following User Says Thank You to del schisler For This Useful Post:
wilard428 (11-27-2010)
Old 11-25-2010, 07:59 PM   #3
the Musigician
DangerMouse's Avatar
Toilet tank bolts
Vise Grips.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
The Following User Says Thank You to DangerMouse For This Useful Post:
Old 11-25-2010, 08:06 PM   #4
Toilet tank bolts
I'll try that. I hope I can find my Dremler.
Old 11-25-2010, 08:53 PM   #5
Civil Engineer
Toilet tank bolts
The last time I had this problem I sawed the old bolt off using a Sawzall and metal blade. Then replaced the bolt. Quick and easy.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
New toilet base doesn't line-up to floor bolts wwsteel7 Plumbing 9 11-25-2010 11:02 AM
tighten Toilet Tank Bolts bmenzie Plumbing 5 10-03-2010 12:24 PM
Toilet tank bolts? FrankL Plumbing 7 09-05-2010 10:32 AM
Leaking tank bolts splinters Plumbing 4 12-25-2009 07:04 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
