Someone has tried to tighten`the bolts that hold the tank to the toilet. The wingnut and bolt is corroded and they tore the slot up on the bolt head. How do I hold the bolt to get the wingnut off?
sound's like you are going to take a hack saw blade and make a new slot. These are brass so shouldn't be to hard to do . If you have a dremel tool with a cutter that would be easy any thing to make a new slot in the bolt
Now when installing the new one's don't tighten to tight or you will brake the tank
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
