Toilet Tank Bolt... - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-03-2011, 05:43 PM   #1
mdawson3k's Avatar
toilet tank bolt...
one of our toilet tank's bolt has been leaking, so i drained it and let it dry.
it is now completely dry. i was wondering if there are different sizes of toilet tank bolt or if they are all the same sizes...
newbie here, appreciate some advice.
thank you.
mdawson3k is offline   Reply With Quote
Old 05-03-2011, 05:45 PM   #2
I have replace quite a few toilet tank bolts they are all the same size Just make sure you get them tightened evenly, and while you are at it you might want to replace the tank to bowl gasket.
merle is offline   Reply With Quote
Old 05-03-2011, 06:04 PM   #3
Framing Contractor
Rewards Points: 120
Be careful removing the tank bolts. The last ones I did were rusted and had to be removed with the grinder.
sixeightten is offline   Reply With Quote
Old 05-03-2011, 08:03 PM   #4
Lightfoot's Avatar
Rewards Points: 272
spend the extra dollar or two and get brass or stainless to put back. much easier off next time
Lightfoot is offline   Reply With Quote
Old 05-03-2011, 08:06 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 682
Remove the bolts (cut if needed)
Remove tank to bowl gasket
Take bolts, the bolts rubber washers and the tank to bowl gasket to the store and buy replacement parts.
Reassemble tank with new bolts and gasket. Tighten bolts evenly and do not over tighten.
Old 05-04-2011, 07:46 AM   #6
Plumb or Die!
Sometimes I'll put a little pipe dope on the washers inside the tank between the washer and the porcelain. On the tank gasket, too.
plumber666 is offline   Reply With Quote
Old 05-04-2011, 10:47 AM   #7
Rewards Points: 1,514
Nowadays most tank bolt kits are generic.
The normal sequence for assembling the parts goes: bolt (head), rubber washer, tank, metal washer, nut, bowl flange, metal washer, nut. The kit may have additional parts and a diagram of where to put them.
As you tighten the lower nut, the center nut may loosen and need more tightening against the bottom of the tank.
Sometimes there is not enough space between the tank bottom and the bowl flange for the nut in between. The tank must not balance on the nut since any shaking of the tank with the hard nut in between will crack the toilet flange or the tank bottom. Then you must either omit that nut and count on the tightness of the nut further below to seal the bolt properly above, or sand the face of the nut so it will be shallower and fit.
Old 05-04-2011, 12:40 PM   #8
mdawson3k's Avatar
Thanks for all the help - Got it done! Yay!
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Leaky Toilet Tank Valve Tuckahoe Sparkplug Plumbing 4 07-10-2010 06:21 AM
Bubbles In Toilet Tank JCNimmo Plumbing 2 01-29-2010 08:11 AM
Stripped toilet tank bolt Sh0eBag22 General DIY Discussions 10 03-24-2009 07:56 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
