Toilet Tank _> Toilet Bowl - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-15-2010, 08:13 PM   #1
Rewards Points: 1,088
How common is it to have leakage between these two parts?
Can you find replacement seals/bolts at your local home store?
What about the cushion washer between them?
handy man88 is offline   Reply With Quote
Old 03-15-2010, 08:25 PM   #2
Rewards Points: 1,016
Yes, it can leak - you can typically find parts at the big box stores.
I like one piece units - no leaks but more-so because they are easy to clean.
Old 03-15-2010, 08:27 PM   #3
Rewards Points: 290
My only experience with this was with a new tank and bowl combo from Lowes. They replaced the tank and that took care of the problem.
Jim F is offline   Reply With Quote
Old 03-15-2010, 08:30 PM   #4
Is the leak more likely between the cushion washer or the bolts?
How often do the nuts on the bolts loose up a bit and just need to be slightly tightened?
Old 03-15-2010, 09:23 PM   #5
Rewards Points: 352
Usually the bolts the rubber washers go bad. While your at it spend the $3.00 for a new tank to bowl gasket
plumberinlaw is offline   Reply With Quote
Old 03-15-2010, 09:31 PM   #6
I checked and it seems that one out of the 3 bolts has very slight moisture on the seal. It appears that this bolt was tightened much less than the other two.
This is a Sterling toilet with the 3 bolt design.
http://www.lowes.com/pd_50751-143-PP...toreBeanArray=[com.lowes.commerce.storelocator.beans.LocatorStore Bean%404b857bc8%2C+com.lowes.commerce.storelocator .beans.LocatorStoreBean%404c33bbc8%2C+com.lowes.co mmerce.storelocator.beans.LocatorStoreBean%403eb63 bcb%2C+com.lowes.commerce.storelocator.beans.Locat orStoreBean%4088bbcb%2C+com.lowes.commerce.storelo cator.beans.LocatorStoreBean%402853bbca]&currentURL=%2Fpl__0__s%3FnewSearch%3Dtrue%24Ntt%3 Dtoilet+repair%24y%3D0%24x%3D0&storeNumber=1538&Nt t=toilet+repair&langId=-1&langId=-1&errorURL=UserAccountView&storeId=10151&storeId=1 0151&Ntk=i_products
Old 03-15-2010, 09:41 PM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Those sterling toilets are poopy !
Journeyman Plumber
Old 03-15-2010, 09:49 PM   #8
Not to go on the cheap, but as the cliche goes, "if it ain't broke, don't fix it."
Therefore, if it's the washer inside the toilet tank, it would appear that the fix can be as straight forward as just removing the bolt and replacing the washer inside the tank without chancing the disturbance of the gasket itself.
Agree?
Old 03-15-2010, 09:54 PM   #9
Doing it myself
Alan's Avatar
Agree?
No. Why? So in a year they can pay someone else to come replace the spud gasket and that someone else will recommend rebuilding the entire tank for the cost of pulling the darn thing apart anyway?
That's all if you get it back together without causing another leak in the process anyway. Knock yourself out.
Journeyman Plumber
Old 03-16-2010, 04:55 AM   #10
If the leak is steady its the bolts, if it only leaks when flushed its the spud gasket
just a guy is offline   Reply With Quote
DIY Tips and Tricks! DangerMouse General DIY Discussions 171 09-04-2015 09:50 AM
Toilet tank to bowl issue. Possibly defective batch? Dr_Jim Plumbing 0 01-18-2010 05:44 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Toilet Bowl Water encouraged Plumbing 2 12-29-2008 09:11 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
