Toilet Tank 1 1/4" From Wall - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-27-2008, 03:42 AM   #1
toilet tank 1 1/4" from wall
hi,
i bought a new comode and didnt measure the "rough in". i bought a 12" "rough in" comode (i know now i should have measured) and installed it. there is plenty of room around the comode. the only thing is, the tank is about 1 1/4" from the wall. it looks alittle weird with tha gap behind the tank, but that shouldnt bother anything right? i mean, its not a lounge chair, so people should'nt lean back on it...bob
bobo60 is offline   Reply With Quote
Old 04-27-2008, 08:51 AM   #2
"i mean, its not a lounge chair, so people should'nt lean back on it...bob"
That's the only real concern, and you're right - people shouldn't, but...
Ishmael is offline   Reply With Quote
Old 04-27-2008, 02:53 PM   #3
...yeah. was thinking of removing tank and putting a few fering strips on either side of wall behind where the tank is for support. i dont really want to replace the new $100+ toilet i just installed...bob
Old 04-27-2008, 09:22 PM   #4
Registered User
Termite's Avatar
The tank or the lid of the tank doesn't have to rest against the wall for support. The tank bolts to the bowl and should be fairly secure unless someone really pushes back hard against it! So, if you can live with it aesthetically, I don't think it will be an issue.
Who says it isn't a lounge chair?!?!?!
Old 04-28-2008, 10:34 AM   #5
With that much space, I would install the strips. Accidents always happen because someone did something they were not "supposed" to do.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 04-28-2008, 11:09 AM   #6
Registered User
Termite's Avatar
I've never installed a toilet so tight to a wall that it touches. The wall is not needed for support in any way at all. The tank lid is all that would touch anyway, and what a nightmare it would be to remove it without messing up the wall's paint if in fact it were tight. I see no reason to fur out the wall unless you can't live with the way it looks.
Old 04-28-2008, 12:08 PM   #7
I always try to leave 1/2" between the wall and the tank. If some 300-pounder leans against the lid/tank, it's close enough to the wall that there shouldn't be a problem. But if that space is 1" or more, I think there's a good chance the tank could crack if a large person decides to lean on it.
Old 05-03-2008, 07:24 PM   #8
I wouldn't worry about and move on to the next project
jbhandyman is offline   Reply With Quote
Old 05-05-2008, 11:40 PM   #9
Doing it myself
Alan's Avatar
Rewards Points: 2,086
You're not supposed to "install a toilet against a wall for support"
Against a wall or not, if a toilet is abused it'll break. Just like anything else we own. Plain and simple.
Journeyman Plumber
Old 05-07-2008, 01:13 PM   #10
Plumbing Contractor
ALan said all that needs to be said.
Boston Plumber is offline   Reply With Quote
Wall mount toilet warnerww Plumbing 3 07-04-2011 09:01 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
