Toilet Superflow Attempt Failure - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-17-2013, 03:55 PM   #1
blksith0's Avatar
Rewards Points: 12
Thumbs up
My toilet wasn't able to handle the loads I was delivering to it, so I figured it was a water pressure issue. I opened up the tank, and that's when I clearly saw the problem. There's a bucket in place, surrounding the flush mechanism around the exit hole. You would flush, but it only allows a certain amount of water through.
I figured if I just cut that bucket up, allowing more water, then it would all be fine and dandy. What could go wrong, right?
Well, the problem is, now a lot more water flows in, and that rubber flush valve wont automatically close because of all the water coming in, which requires me to manually turn off the water supply.
I guess that plastic bucket was there for a reason.
So my question is, how bad is this situation? I don't know how to replace that bucket since it's attached to the bottom of the tank. What would you guys do?
blksith0 is offline   Reply With Quote
Old 09-17-2013, 04:04 PM   #2
I would cut the rest of the bucket out.
broox is offline   Reply With Quote
Old 09-17-2013, 04:40 PM   #3
Rewards Points: 2,634
What do you mean the flapper won't automatically close? Normally, when you flush, the flapper raises and floats on top of the water. When the water level drops, the flapper drops onto the seat. Seems rather foolproof. That rather looks like a standard flapper.
Sometimes the chain can get under the flapper.
SPS-1 is offline   Reply With Quote
Old 09-17-2013, 04:56 PM   #4
blksith0's Avatar
Rewards Points: 12
I could always use tape to patch up those two holes. Probably wouldn't last long though.
Old 09-17-2013, 04:58 PM   #5
blksith0's Avatar
Rewards Points: 12
I should have said, the flapper doesn't automatically close soon enough. The amount of water that flows into the toilet is too much, threatening to overflow, and the flapper stays open and lets it all flow down.
I could always get a half-gallon, fill it with water, put in the tank, and that would reduce the volume of water allowed to flow...
Old 09-17-2013, 05:37 PM   #6
You can adjust the water level in the tank. The float will be adjustable. You can likely find a You-Tube video that shows water level adjustment on your style of fill valve.
The Following User Says Thank You to SPS-1 For This Useful Post:
blksith0 (09-18-2013)
Old 09-17-2013, 06:00 PM   #7
Oso954's Avatar
Rewards Points: 994
I wouldn't screw with it. I would just rip it out and replace with a new toilet. Preferably a Toto.
Oso954 is offline   Reply With Quote
Old 09-17-2013, 06:36 PM   #8
Rewards Points: 20
Get a Fluidmaster universal flapper. The flapper is rotated to adjust the duration of the flush.
Dan
djlandkpl is offline   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
Old 09-17-2013, 06:46 PM   #9
Rewards Points: 1,858
Honestly I would take that first generation 1.6 gallon flush gerber toilet out. Open the window and see how far you can toss it and go purchase a name brand 1.6 gallon toilet. I use the American standard right height it works very well. Toilet Plunger collects dust good also now.
Old 09-17-2013, 08:36 PM   #10
Master Plumber
Javiles's Avatar
Rewards Points: 994
Replace the complete flush valve, the reason the flappers not setting is to much pressure going in to the over flow tube, pull back the black refill tube and try and slow down the flow to it.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
Old 09-17-2013, 09:08 PM   #11
Originally Posted by Oso954 View Post
...rip it out and replace with a new toilet. Preferably a Toto.
or a Ferguson
Old 09-17-2013, 09:52 PM   #12
To me, it seems silly to replace a toilet that can be repaired. I have done what you have attempted several times to make the toilet flush better. If memory serves, once I cut up the "bucket" like you did. One big gash on one side and the flapper did not function correctly. The water flowing in from one side,I think,affects the flapper closing properly. I would trim a lot more of the bucket away, and if you need to, adjust the fill valve so there is less water in the tank. Good Luck!
The Following User Says Thank You to broox For This Useful Post:
Old 09-18-2013, 10:11 AM   #13
Plumber
The bowl should be able to keep up with the flow of water coming out of the tank.
If its not then you may have a blockage in the trap way of the toilet and or in the drain line under the toilet.
I would start with a toilet auger and if that doesn't work , you may need to remove the toilet and have the drain cabled out.
DidIDoThat is offline   Reply With Quote
The Following User Says Thank You to DidIDoThat For This Useful Post:
Old 09-18-2013, 10:46 AM   #14
K&B Designer
Live_Oak's Avatar
Replace that POS and don't look back. You can't "repair" a defective design.
Live_Oak is offline   Reply With Quote
Old 09-18-2013, 06:02 PM   #15
If you enjoy using a plunger then keep it. I had 2 I now have 0. That should be enough said.
downstairs toilet now leakiing after replacing upstairs toilet davesj Plumbing 3 12-03-2011 05:03 PM
Help with stink coming from Toilet area. Integraoligist General DIY Discussions 9 11-16-2011 05:16 PM
Toilet location has become a bit of a problem BOUTYM Plumbing 13 10-10-2011 11:19 AM
Repair 1962 Rheem pink toilet tank or find vintage replacement ? khaef Plumbing 0 09-09-2011 09:55 AM
Where to Move this Toilet? estburke Plumbing 8 10-10-2010 11:52 PM
