Toilet Spacing - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-08-2011, 08:36 PM   #1
toilet spacing
what is the minimum spacing requirement for a toilet?
BB4nier is offline   Reply With Quote
Old 02-08-2011, 08:49 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 350
From the finish wall:
15" off the side wall.
12" off the back wall is typical. 10" will work if you use a toilet designed for 10" set.
Old 02-09-2011, 03:22 AM   #3
Homerepairguy's Avatar
Rewards Points: 990
The measurements Eplumber gave are to the center of the drain pipe.
HRG
Homerepairguy is offline   Reply With Quote
Old 02-09-2011, 08:27 AM   #4
In most Codes, you must have 15 from the center to any wall or cabinet. Not aware of any stated distance from the front or rear but this is usually set by the rough-in measurement.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 02-10-2011, 02:58 PM   #5
remodeling pro
IRC requires a mininum of 21" from the front of the toilet to any door, wall, cabinet, etc located across from it. This is mininum, and while it feels ok if the object is a tub or vanity cabinet, it can be uncomfortable for some to be facing a wall or closed door that close. Same thing goes for the width. While a toilet between two walls that are 30" apart is legal, it is certainly not comfortable; and always creates issues with where to mount the tissue holder.
troubleseeker is offline   Reply With Quote
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Toilet Spacing gerhardt Kitchen & Bath Remodeling 0 05-20-2010 11:34 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Toilet spacing issues... KC10KEVIN Plumbing 4 05-09-2008 12:27 AM
