#1 |
Toilet sounds like a semi-truck
When I flush my toilet and its almost full - the last few seconds the water pipes shake so much it sounds like a semi-truck driving by the house. The first 3/4 of the tank are fine but the last bit is rough. Any ideas? I have replaced the flapper portion as it was leaking by.
Not sure what to do and afraid its going to shake the side of the house off. Thanks |
#2 |
Just call me Andrew
Can you tell which pipes are shaking? Is it the pipe coming out of the wall, down in the basement, or inside the toilet?
Andrew |
#3 |
The short answer is yes. You can see it in the pipe in the toilet but the sound is coming from the basement I think.
#4 |
In an effort to remedy the noise I have: 1 - replaced the center piece with what used to be a flapper on it, 2 - checked the water lines to make sure that there werent any that were partially cloed. Beyhond that I am at a loss.
#5 |
replace the fill valve. get a fluidmaster 400a. problem solved
#6 |
Replace the fill valve - the one that the water enters the toilet through. I replaced the other one - the one that the water leaves the toilet through but not the other one.
I will give it a try. Thanks!!! |
| Display Modes | |
| Can't figure out where the toilet is leaking??? Interior? | CostcoMan | Plumbing | 11 | 04-13-2010 02:47 PM |
| Help me check my logic on clogged drain and overflowing toilet | Southlake_Ed | Plumbing | 10 | 01-05-2010 08:52 PM |
| Basement Toilet Rough In - Help | atm | Plumbing | 3 | 06-06-2009 12:04 PM |
| Toilet install - 2 questions | BataviaJim | Plumbing | 11 | 05-11-2009 02:53 PM |
| My toilet sounds like a foghorn | katzpjs | Plumbing | 5 | 03-15-2005 04:33 PM |
