Old 08-02-2009, 02:25 PM   #1
toilet for small space
Hi all,
I moved into a new house a few months ago where the previous owner started framing out a bathroom in the basement. If you could imagine walking into the bathroom, to the left there is a finished wall that is about 20" past the door frame - that is where I would like the back of the toilet to go. Does anyone know of a toilet that can be mounted closer to the wall, or would "hug the wall" closer than a 10" rough? Worse case scenario I could move the door over a little, relocate the toilet, or create an alcove for the tank, but before doing so I figured I would explore other options. the toilet drain is not run yet so I do have lots of options, but if I could find say an 8" rough toilet (which I've never seen) I figure that might be the easiest and give me the nicest look.
Thank you!
mazzonetv is offline   Reply With Quote
Old 08-02-2009, 02:59 PM   #2
35 YEAR MASTER PLUMBER
MACPLUMB's Avatar
Exclamation
THEIR IS "NO" SUCH THING AS A SMALLER TOILET THE 10" ROUGH IS AS SMALLEST IT GETS CHANGE THE PLUMBING DOOR OR CONSTRUCTION AS NEEDED !
35 YR. MASTER PLUMBER WITH PH.D IN WATER HEATERLOGY, MASTERS DEGREE IN DRAINLOGY,
PLUMB ANY PIPE, SNAKE ANY DRAIN, MAKE COLD WATER BOIL ON A FREEZING DAY
MACPLUMB is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 12:04 PM
What are the 'code' space requirements for a toilet in a three walled area?? 4just1don General Discussion 6 05-21-2009 10:40 PM
Sealing the space between the toilet and the floor... pro_DIYer General Discussion 4 07-11-2008 02:25 PM
