Toilet Slowly Draining, Sink Causes Level To Rise - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-31-2012, 09:29 AM   #1
Toilet slowly draining, sink causes level to rise
I installed the toilet in my bathroom on Wednesday and have had no problems at all, but last night on thursday the toilet wouldn't flush. The water level would just rise. I tried using a plunger but that had no effect, other than hearing water near the sink move around. I left it overnight and the water level in the toilet went down to a minimum, so it is slowly draining, but not flushing. When I use the sink, the water level in the toilet rises and the water bubbles (obviously the water is going back up the pipe to the toilet or something). Do I have a clog in the pipe that is stopping 100% water flow or something? Let me know what you think. Thanks.
emeryj23 is offline   Reply With Quote
Old 08-31-2012, 09:37 AM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 990
Stoppage Now you need to determine if its the branch or the whole System.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 08-31-2012, 09:57 AM   #3
DIY staff
Rewards Points: 7,174
You have a blockage--past the T from the toilet /sink---could be the main line from the house--or could be right there----
I suggest you pull off the toilet and rod out that line---you may need to rent an auger for a 3 inch line----
You mentioned recently installing that toilet---any possibility that construction debris or a rag was left in the pipe?
Old 08-31-2012, 01:17 PM   #4
DIY Enthusiast
+1 that's exactly what I was thinking...
ajmckay is offline   Reply With Quote
Old 09-04-2012, 11:28 AM   #5
DIY Enthusiast
Soooo... Did you find the blockage?
NEW sink and plumbing is slow draining, no overflow, pipes not clogged ymi2b Plumbing 15 09-10-2015 09:29 PM
Sink no longer draining after cleaning trap adnerbs Plumbing 3 11-18-2010 09:31 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
Toilet flushes slowly, but no visible clogs... poorboye Plumbing 4 09-13-2007 12:02 PM
