-   -   Toilet slowly draining, sink causes level to rise (http://www.diychatroom.com/f7/toilet-slowly-draining-sink-causes-level-rise-155392/)
emeryj23 08-31-2012 09:29 AM
I installed the toilet in my bathroom on Wednesday and have had no problems at all, but last night on thursday the toilet wouldn't flush. The water level would just rise. I tried using a plunger but that had no effect, other than hearing water near the sink move around. I left it overnight and the water level in the toilet went down to a minimum, so it is slowly draining, but not flushing. When I use the sink, the water level in the toilet rises and the water bubbles (obviously the water is going back up the pipe to the toilet or something). Do I have a clog in the pipe that is stopping 100% water flow or something? Let me know what you think. Thanks.
Javiles 08-31-2012 09:37 AM
Stoppage Now you need to determine if its the branch or the whole System.
oh'mike 08-31-2012 09:57 AM
You have a blockage--past the T from the toilet /sink---could be the main line from the house--or could be right there----
I suggest you pull off the toilet and rod out that line---you may need to rent an auger for a 3 inch line----
You mentioned recently installing that toilet---any possibility that construction debris or a rag was left in the pipe?
ajmckay 08-31-2012 01:17 PM
+1 that's exactly what I was thinking...
ajmckay 09-04-2012 11:28 AM
Soooo... Did you find the blockage?
