Old 07-10-2008, 02:20 AM   #1
Toilet size
I need to install a new toilet, but not sure if there is a difference in sizes between toilets or is it a standard size? If there are different sizes what do I measure to know what size toilet I need?
Thanks,
-Dank
dankreboot is offline   Reply With Quote
Old 07-10-2008, 02:32 AM   #2
Toilet size
The measurement you need to be concerned with is the distance from the rear finished wall and the center of the drain. It should be 12 inches. 12 inches is standard. if you have more or less you can get a 10" or 14" but they are not the norm.
plumber Jim is offline   Reply With Quote
Old 07-10-2008, 09:05 AM   #3
Licensed Master Plumber
mstplumber's Avatar
Toilet size
To add to Jim's comments, which are correct, if it's a little more than 12" from the center of the drain you can probably still use a standard 12" rough toilet. You just don't want the back of the tank to be much more than about an inch away from the wall, so 13" is probably about the max. If it's much less than 11 1/2" you will need to buy a 10' rough in model.
Mstplumber
Check out my goofy video for my new
mstplumber is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 04:43 PM
Need opinion - Need help - I believe my toilet was not installed properly rdlegacy Plumbing 9 05-06-2008 06:03 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
Installing an attach-to-floor toilet? johnny4321 Plumbing 5 11-22-2007 02:34 AM
