-   -   Toilet size (http://www.diychatroom.com/f7/toilet-size-23450/)
dankreboot 07-10-2008 02:20 AM
Toilet size
I need to install a new toilet, but not sure if there is a difference in sizes between toilets or is it a standard size? If there are different sizes what do I measure to know what size toilet I need?
Thanks,
-Dank
plumber Jim 07-10-2008 02:32 AM
The measurement you need to be concerned with is the distance from the rear finished wall and the center of the drain. It should be 12 inches. 12 inches is standard. if you have more or less you can get a 10" or 14" but they are not the norm.
mstplumber 07-10-2008 09:05 AM
To add to Jim's comments, which are correct, if it's a little more than 12" from the center of the drain you can probably still use a standard 12" rough toilet. You just don't want the back of the tank to be much more than about an inch away from the wall, so 13" is probably about the max. If it's much less than 11 1/2" you will need to buy a 10' rough in model.
