Toilet/shower Stack Layout - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-26-2012, 03:55 PM   #1
Rewards Points: 150
Toilet/shower stack layout
Remodeling a bathroom including replacing the toilet and shower. We have always had problems with the shower draining slowly. It is a shower bath so the pipe is 1 1/2. We are going to stick with a shower/bath, except upgrade the drain to 2 inch to improve draining now and preparation for shower only when we get older.
Here is how the pipes are currently layed out.
Toilet/shower stack layout-bathroom-stack.jpg
Can anybody explain why the shower drain goes across the front of the toilet drain, then enters the stack?
I would like to replumb it as shown below. Any advise?
Toilet/shower stack layout-bathroom-stack-new.jpg
goosebarry is offline   Reply With Quote
Old 04-26-2012, 09:53 PM   #2
Rewards Points: 582
Attachment 49774
Attachment 49775
you da man go for it....
The Following User Says Thank You to ben's plumbing For This Useful Post:
goosebarry (04-27-2012)
Old 04-27-2012, 10:51 AM   #3
Rewards Points: 87
Maybe the shower was added after the toilet?
George6488 is offline   Reply With Quote
Old 04-27-2012, 01:33 PM   #4
Rewards Points: 150
No original to the house. It was a 500 house subdivision and I figure the plumber only had Sanitary Tee with Left Inlets not Right Inlets, but when I looked more closely it currently is a 1 1/2 inch inlet over the Sanitary Tee.
Old 04-27-2012, 01:46 PM   #5
I dont see a problem, but in fact tis hould have been the way.
If you want a quicker drain, try using a Y instead of the Tee and a 45 and improve the elbows with 2x 45 and a little pipe between them. The less sharper the curve, the easier the water drains
BNTHERE is offline   Reply With Quote
The Following User Says Thank You to BNTHERE For This Useful Post:
OOPS! Stack disconnected when I tested my work... WillK Plumbing 1 02-20-2012 07:04 AM
plumbing stack issues? BlueBSH Plumbing 0 08-12-2011 11:12 AM
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 10:00 AM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
DWV Stack Question dcgray2 Plumbing 9 07-14-2006 01:56 PM
