Toilet And Shower Rough In Dimensions - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-08-2012, 09:26 AM   #16
JOATMON
ddawg16's Avatar
Rewards Points: 1,818
Here is a link with more details on the rough in....
Professor Toilet......the guy really knows his sh!t.....
Sorry.....couldn't resist....
Old 05-13-2012, 01:50 PM   #17
Thank you for the Professor Toilet post but it appears to state things differently than I understand.
Here is what the site states:
When talking toilets, the toilet rough in is the distance from the wall behind the toilet to the center of the outlet pipe where the waste leaves the toilet. The most common distance is 12 inches, so most toilets have a “12-inch rough.”
Is the outlet pipe where the waste leaves the toilet the PVC pipe in the floor? If so, I thought it was 12 inches from the wall to the closet part of the PVC pipe in the floor (not the center). Should I be measuring from the center of the pipe to the wall?
Also, just as an FYI, I went to Home Depot and they have VERY few 10 inch rough in toilets. I am going to do everything I can to make the rough in 12 inches just so I do not have to special order a toilet… don’t want to spend all my money on a toilet.
VikingDinKC is offline   Reply With Quote
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 11:04 AM
No flow to shower head; toilet runs constantly kathleentsy Plumbing 7 05-17-2007 09:05 AM
Shower Body, Toilet Water Supply Rough helpless handyman Plumbing 5 11-06-2006 08:51 AM
