Toilet Seals - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-30-2009, 03:29 PM   #1
toilet seals
Just replaced wax seal on leaky toilet. Still leaks. Everything is level, see no cracks on toilet (cld be in the trap), tried to blame the grandkids, but it leaked before they visited. Flange is about 1/2 inch above the floor level, we have read about hammering it down using a piece of wood and are going to try that. We are old, Husband doesn't want to pay plumber of course, nor go under the house. If I could just get him to go away for a while, I'd hire me a plumber. Help Vicki and Dick
VickiTun1 is offline   Reply With Quote
Old 01-31-2009, 12:09 AM   #2
I would take a small sledgehammer and beat down on it till it drops. You are going to have to hit it really hard to make it go down. then replace the wax ring.
John McCabe is offline   Reply With Quote
Old 01-31-2009, 02:01 AM   #3
Rewards Points: 2,906
VickiTun1:
What do you think about the idea of tracing the toilet's "footprint" onto a piece of 1/4 inch plywood, sticking that plywood down to the floor with double sided carpet tape and installing the toilet over that plywood? That way you raise the toilet rather than lowering the flange.
John:
How would hammering on the toilet flange accomplish anything other than wrecking the toilet flange? That is, in what way would the toilet flange "drop" as you describe.
I'd be concerned that you're as likely to damage the subfloor supporting the toilet flange before it "drops", and any such "dropping" may be irrepairable without pulling up the flooring, underlayment and replacing some floor boards with plywood. And, as luck would have it, those floor boards may go under the walls, and replacing them may simply not be feasible without cutting a large hole in the ceiling below to get good access to them.
I don't think it's ever appropriate to hammer on a toilet floor flange. Or, at least, this is the very first time the idea has come up in my experience, and I simply can't see the benefit in doing that. I can see a lot of problems resulting from doing that, tho.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 01-31-2009, 05:09 AM   #4
the Musigician
DangerMouse's Avatar
i have to go with nestor here.... what if the toilet is on a second floor? and it's gone rotten underneath? hitting it with a slegehammer would send the OP to the next floor below! and what if it's a toilet in a basement? with the hole in concrete? smash the concrete?
i've seen toilets installed numerous ways, but never with a plywood ring around the bottom... sorry nestor, but how do you clean it? *YUK*
so, what is the flange made of? iron? PVC?
perhaps shortening the flange would be a smarter idea? although, i'd certainly verify the flange seal is the culprit first! ("see no cracks on toilet, cld be in the trap") if i were you, i'd ask around to some/any handy relatives or friends you may know to take a close look at it before you proceed. for us to assist you here, i believe we will need some more details from you, Vicki. location, age, and floor level of toilet? perhaps pictures would help as well. i fixed a toilet problem once that the guy had tried 3 times with wax rings to stop a leak that was coming from the seal between tank and bowl......
DM
Old 01-31-2009, 12:20 PM   #5
Hammering the flange down will fix the problem. There is movement in those lines. You have to beat really hard but it will go down.
Why would anyone want to build up a toielt with wood? Not a good idea and the fix is a sledgehammer. Besides, if you read, they already mentioned they was going to do this.
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Fernco waxless toilet seals Duane 70 Plumbing 8 01-02-2009 01:35 PM
Toilet Leaks When Flushed - How to get at closet bend!! OldHouseNewProblem Plumbing 3 12-11-2008 06:24 AM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 04:28 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
