Toilet Seal, Wax Or Foam Rubber - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-03-2010, 10:20 PM   #1
toilet seal, wax or foam rubber
I am putting a toilet in my basement that has the rough in plunbing. The problem is they did not install a flange and cemented right to the top of the drain. In order to save me some chipping concrete work I thought I would install a flange that goes inside the drain rather than over it. The plumber at Home Depot told me I could not use a wax seal but had to use the rubber one. I installed it using the rubber one get a leak at the seal. Why can and I not use a wax seal? I would think that once it gets forced down it would seal much better. Any comments. And as always thanks in advance. The help here is awesome.
beech is offline   Reply With Quote
Old 12-03-2010, 11:00 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 904
Did you actually install the flange? I hope so.
I always use wax rings on floor mounted toilets and foam for wall hung toilets
Old 12-04-2010, 08:09 AM   #3
Yes I installed the flange. Think I might have cracked it tho. Just wondered why the plumber would tell me to not use wax when using an inside fitting flange. Thanks.
Old 12-04-2010, 08:25 AM   #4
Plumber
Rewards Points: 904
At HD you talked to a salesman not a plumber
Old 12-04-2010, 09:06 AM   #5
I agree with Eplumber. HD does hire one person that is actually a Plumber, but the rest of them are shelf stockers with little to no knowledge.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-04-2010, 12:38 PM   #6
Thanks guys. I did buy a wax seal and reinstalled the toilet. Looks like all is well, no leaks so far. Thanks for your help.
Where to Move this Toilet? estburke Plumbing 8 10-10-2010 11:52 PM
Hybrid wall insulation consisting of 2" rigid foam + 2x4 fiberglass batts? TitaniumVT Building & Construction 15 09-14-2010 02:50 AM
Has anyone tried a wax free toilet seal? I believe it's rubber? bobpipe Plumbing 5 08-21-2009 01:09 AM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 10:14 AM
Piece on bottom of toilet tank won't seal Squeeealer Plumbing 1 07-14-2005 08:13 PM
