-   -   toilet seal, wax or foam rubber (http://www.diychatroom.com/f7/toilet-seal-wax-foam-rubber-88536/)
beech 12-03-2010 11:20 PM
I am putting a toilet in my basement that has the rough in plunbing. The problem is they did not install a flange and cemented right to the top of the drain. In order to save me some chipping concrete work I thought I would install a flange that goes inside the drain rather than over it. The plumber at Home Depot told me I could not use a wax seal but had to use the rubber one. I installed it using the rubber one get a leak at the seal. Why can and I not use a wax seal? I would think that once it gets forced down it would seal much better. Any comments. And as always thanks in advance. The help here is awesome.
TheEplumber 12-04-2010 12:00 AM
199 Attachment(s)
Did you actually install the flange? I hope so.
I always use wax rings on floor mounted toilets and foam for wall hung toilets
beech 12-04-2010 09:09 AM
Yes I installed the flange. Think I might have cracked it tho. Just wondered why the plumber would tell me to not use wax when using an inside fitting flange. Thanks.
TheEplumber 12-04-2010 09:25 AM
199 Attachment(s)
At HD you talked to a salesman not a plumber
majakdragon 12-04-2010 10:06 AM
I agree with Eplumber. HD does hire one person that is actually a Plumber, but the rest of them are shelf stockers with little to no knowledge.
beech 12-04-2010 01:38 PM
Thanks guys. I did buy a wax seal and reinstalled the toilet. Looks like all is well, no leaks so far. Thanks for your help.
