Toilet Was Roughed In At 11.5! - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-11-2011, 12:19 PM   #1
Rewards Points: 35
Toilet was roughed in at 11.5!
Hey guys,
Went to install a toilet today and discovered my contractor roughed in the toilet BEFORE furring the walls out. So now I tried to install a toilet and it won't work. What are my options here? I found 10" rough in toilets, so the only issue there would be is a 1.5" gap between the tank and the wall. To make matters worse, the floor is already tiled.
tunabreath is offline   Reply With Quote
Old 12-11-2011, 12:52 PM   #2
Rewards Points: 582
Originally Posted by tunabreath View Post
Hey guys,
did you try to install 12" rough alot of times tank will hit back wall but seal into the bowl without leaking...if it will not fit.... 10" rough thats it...small gap in back ok. may not look the best....but most would not notice...
Old 12-11-2011, 01:00 PM   #3
the Musigician
DangerMouse's Avatar
I thought they made a fitting for just this occasion? It rotates to fit exactly?
Anyone?
DM
Old 12-11-2011, 01:13 PM   #4
Rewards Points: 334
I think you are referring to an Offset Toilet Flange. (I have no opinion or experience with them, just remembered a thread on these.)
tribe_fan is offline   Reply With Quote
The Following User Says Thank You to tribe_fan For This Useful Post:
DangerMouse (12-11-2011)
Old 12-11-2011, 02:21 PM   #5
Rewards Points: 35
Tank is right against wall. Can't put lid on without having the lid tilted forward which will make it prone to falling off and also the seat will not stay up.
Offset flange would prob work but I would still have to cut tile out so the offset flange would not be higher than finished floor.
Old 12-11-2011, 02:31 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Hey guys,
did a plumber rough it in or a contractor?
did he know wall was being furred out/finished? if he knew it id say he should come back and fix it
plummen is offline   Reply With Quote
Old 12-11-2011, 02:47 PM   #7
If the plumbing under this is easy to get to like in a crawlspace or basement, then I would say move it to the correct distance.
Mark the area the toilet will cover if installed the correct distance, then see if moving the connection and wrecked tile will be under the correctly installed toilet.
Billy_Bob is offline   Reply With Quote
Old 12-11-2011, 03:11 PM   #8
Rewards Points: 582
if tank is against wall and lid won't fit....and you want to get done install the 10" rough.....unless the plumber or contractor is going to fix it...
Old 12-11-2011, 03:26 PM   #9
MikeKy55's Avatar
Rewards Points: 254
Some 12" units will fit in that space albeit tight. I just put a 12" in my basement with 11.5" finished wall to center of flange.
'It's never too late to say ''THANK YOU'' to a veteran of our armed services'
MikeKy55 is offline   Reply With Quote
Old 12-11-2011, 03:27 PM   #10
Rewards Points: 35
Contractor did it I think. Totally his mistake.
If I can't make something work, then he is going to have to fix it.
Thanks guys.
Old 12-11-2011, 03:30 PM   #11
Plumber
TheEplumber's Avatar
Rewards Points: 452
Hey guys,
Your options:
1 Move the rough in yourself
2 Make the plumber move it
3 Set a 10" toilet and back-charge/deduct the contractor for the cost difference between 10" & 12" toilet
The Following User Says Thank You to TheEplumber For This Useful Post:
VIPlumber (12-11-2011)
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 08:41 PM
Toilet wont drain chazlew Plumbing 11 02-27-2011 11:08 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
