Toilet Rough-in - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-20-2011, 11:49 AM   #1
Rewards Points: 640
toilet rough-in
I am redoing a bathroom and the toilet roughin that should be 12" to the center of the drail turns out to be about 11.5" will this be a problem? how much give do toilets usually have with rough in's? I know my one toilet in my master bath has a 12" rough-in but has about 2" of clearance behind the tank..
BlueBSH is offline   Reply With Quote
Old 01-20-2011, 11:58 AM   #2
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 682
They make toilets with a range of rough-in sizes. Most common is 12", but 10" is also quite-available if a 12 is going to be too tight.
hyunelan2 is offline   Reply With Quote
Old 01-20-2011, 12:03 PM   #3
Rewards Points: 256
I heard once that there are some toilets made to fit a 10" rough-in.
Don't know if it's true haven't checked.
michaelcherr is offline   Reply With Quote
Old 01-20-2011, 12:04 PM   #4
Rewards Points: 460
You may have to dry fit tank (with lid) if a 2 piece unit to check wall clearance. Allow for tile depth if you're tiling. Check with significant other if acceptable/too tight.
Easier to swap an uninstalled toilet than to relocate a waste pipe.
diyorpay is offline   Reply With Quote
Old 01-20-2011, 12:21 PM   #5
Rewards Points: 3,130
There may also be other brands, but the Glacier Bay toilets I bought at Home Depot have an adjustment of almost 3 inches for the tank. You can basically set the clearance to the wall at whatever you want.
Old 01-20-2011, 12:29 PM   #6
Rewards Points: 268
Just had to return a new toilet that was made for a 12" rough-in, and get one for a 10" rough-in. This is in a townhouse. Vey tight bathroom. HD had 1 style in stock, but could order different colors and styles.
packer_rich is offline   Reply With Quote
Old 01-20-2011, 01:02 PM   #7
Rewards Points: 640
I guess I am in a good situation, I have 4 toilets to replace, 3 of them have 12" rough ins... so if I can't dry fit a 12" on this one then it will just go onto one of the other ones due for replacement
Old 01-20-2011, 08:06 PM   #8
Rewards Points: 262
My American Standard Cadet 4 sits about one inch away from the wall with a 12" rough in. I wish the tank did press up against the wall. With kids I always worry that they are going to lean back and cause the tank to leak. So there is room to play with that model at least.
Jim F is offline   Reply With Quote
The Following User Says Thank You to Jim F For This Useful Post:
oh'mike (01-20-2011)
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 12:04 PM
Replace a 10" rough in toilet with a 12" rough in Opie46 Plumbing 3 05-16-2009 12:27 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Move basement toilet rough in 6-8" HVACman Plumbing 5 04-19-2008 08:45 PM
