Toilet Rocks On Tile Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-18-2012, 09:10 PM   #16
Rewards Points: 1,500
You need to correct the rocking problem and test the fit of the toilet in place before installing the wax ring.
If you already experienced rocking after "final" installation then the wax ring you have is probably deformed too much to reuse. Unlike rubber, wax does not fluff back out after the pressure that is squeezing it is relieved.
Old 11-18-2012, 09:21 PM   #17
Originally Posted by Anianna View Post
Thank you. Our place was built in the mid-90s, are you sure it's poly b by Zurn?
99.9% certain. Our place was built in '94 and had it.
VIPlumber is offline   Reply With Quote
Old 11-18-2012, 09:31 PM   #18
Rewards Points: 98
Thanks all for the info regarding the wax ring.
From what I understand from a bit of research, the failure is caused by a reaction of the polymer with chemical chlorine common in American public water systems. Polybutylene systems are still in use and are even popular in Europe and Asia. I know in at least parts of Europe, they don't use chlorine to treat water, but use Oxine instead, so that may be why it isn't a problem in those markets. Our water comes from a well and is not chlorinated, so I think we'll be fine, but I will look into it further to make sure.
Anianna is offline   Reply With Quote
Old 11-19-2012, 12:04 PM   #19
Awesome Answers !
Thanx Richo for posting your question. I have the same exact problem. And after spending so much time making sure that I mixed the floor leveller exactly to direction, & levellling each & every tile along with the over-all floor after placing each tile, I was devastated to find out that my toilet didn't fit snug! I really appreciate everyone's answers. Thank you so much !! I had no idea that they made plastic shims for this. I've heard of the composite ones, actually thought about using them, but they do have a terrible odour that I can not seem to find out any info from anyone about how long that odour lasts. Plastic it is ! I am also going to use caulk in dabs underneath the toilet, just to set it in place.
RikksTamo is offline   Reply With Quote
toilet install over new tile floor dbrew Plumbing 11 07-08-2014 08:34 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Tile over existing tile floor? dwalls32 Remodeling 3 07-03-2007 04:19 PM
Adding toilet in basement with tile on the floor Kyle Plumbing 6 09-13-2006 08:59 PM
Kiwi tile for woodshop floor? rbh Flooring 2 08-20-2006 03:44 PM
