Old 02-15-2010, 12:40 AM   #1
Toilet riser issue
I just replaced the whole sub-floor, joists, & finished floor in my mother-in-law's bathroom in a very old house. The riser is cast iron. The problem seems to have a simple solution but nobody @ the small hardware store there knows what I'm talking about.
The floor was completely rotted & falling through. After replacing the floor, the riser sits about 1 foot under the sub-floor & it has what looks like a 'crush sleeve' in it that goes up to the flange. It's crushed due to the floor caving over the years & needs to be remedied. Anyone have a clue what it is, where I can get another, or another solution?? Please help. It's all I need to finish this project
JJ2790 is offline   Reply With Quote
Old 02-15-2010, 06:41 AM   #2
Toilet riser issue
Are you talking about the drain?? Not sure to what you refer(a pic would help), but my guess, if the house if very old, is a lead collar of some sort. Try a plumbing supply house.
Old 02-15-2010, 07:50 AM   #3
the Musigician
DangerMouse's Avatar
Toilet riser issue
Hi and welcome to the forum.
As Bill stated, a picture or two always helps here!
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 02-15-2010, 10:59 AM   #4
Toilet riser issue
Yes I wish I took a pic. She lives 2.5 hours away from me. It is the drain, & you're right, it looks like a thin lead collar of some sort. Thank you
Old 02-15-2010, 11:31 AM   #5
the Musigician
Toilet riser issue
Like Bill said, call around to plumbing supply stores.
(You'll likely not find these at the BB stores. Maybe, but I dunno....)
Did you already pull the broken one, so you can show the guys at the PS store?
Or at least measure it?
DM
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 08:38 PM
Toilet Issue - Flap Sticking to Ball booyah Plumbing 3 01-14-2010 09:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
New Toilet issue turbomangt Plumbing 9 09-18-2009 10:45 AM
Toilet running water leaking issue? mikehende Plumbing 16 06-01-2009 11:07 AM
