Old 12-17-2012, 04:26 PM   #1
Toilet Ring Placement
What is the distance from my finished wall to the toilet ring? I think I read somewhere in the past that it was 12" to the center of the ring?
Also do I install this ring on top of my 1/4" cement board? Cement board in for the future tile.
Thank you
bigfishcatcher3 is offline   Reply With Quote
Old 12-17-2012, 04:35 PM   #2
"Nail-Bender"
If you mean "wax-ring", when you say toilet ring.
Don't install it on the sub-floor, the cement-board, tile!!!!
It goes against the "toilet-flange" on the plumbing and seals against the bottom of the toilet.
The more you raise the toilet; in relation to the floor -
the thicker wax-ring you're going to need!
rossfingal
Yeah - the distance from the wall to the center (where the bolts on the floor-flange are)
is usually 12 inches -
Remember -
If you're building out the walls (cement-board, tile, etc...)
That will decrease the distance!!
rossfingal is online now   Reply With Quote
Old 12-17-2012, 04:35 PM   #3
call me E
TheEplumber's Avatar
Center of flange- no less then 12" to face of finished wall
Top of flange should not be below finished floor level- my opinion
Old 12-17-2012, 04:40 PM   #4
Oops sorry meant toilet flange. Ok no less then 12" from center of flange to finish wall. If I install it on top of the cement board and then tile around it would it be flush with the tile? If you like it higher than the finish floor should I built it up another 1/4" or whatever the tile thickness is so it higher then the tile (finish floor)?
Old 12-17-2012, 04:52 PM   #5
"Nail-Bender"
Cement board - under-layment does not go over the the toilet flange on the floor!!!
Good!!
"TheEplumber" has shown up!!
That person can make things clearer!
Happy Holidays!
Old 12-17-2012, 04:55 PM   #6
DIY Enthusiast
sublime2's Avatar
Generally you want the flange slightly above the finished floor. Never below it.
sublime2 is offline   Reply With Quote
Old 12-17-2012, 05:00 PM   #7
Ross yes I understand the cement board does not go over the flange thank you.
Old 12-17-2012, 05:19 PM   #8
"Nail-Bender"
Just trying to be; somewhat, clear!
Happy Holidays!
"RF"
Wax Toilet Ring Question cabinetman Plumbing 2 05-31-2009 11:12 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Toilet Wax Ring & Horn capt2 Plumbing 2 07-19-2008 10:24 PM
toilet leak after replace new wax ring druffino Plumbing 4 07-17-2008 11:31 PM
Which is better? WAX or Non-Wax toilet ring? KUIPORNG Plumbing 15 02-20-2008 03:23 AM
