Toilet Requires Multiple Flushes - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-28-2012, 10:43 PM   #1
Toilet requires multiple flushes
We built 28 years ago, 3 toilets, 5 gallon old style tanks. In the last year, all three toilets have started requiring two flushes to "get the job done". All nearby fixtures are used daily, so the traps are not dry. Seem to have lots of water. Any ideas?
rickdulaney is offline   Reply With Quote
Old 04-29-2012, 12:12 AM   #2
Homerepairguy's Avatar
Rewards Points: 990
Have you put bricks in the tanks to reduce the amount of water per flush? Or lowered the water level in the tanks by adjusting the floats? If so, the duration of filling the tanks would be shortened > shortening the duration of the water flow into the overflow tube > resulting in less than maximum water level in the bowls > resulting in poor flushing.
Or the holes in the underside of the bowl's upper rim might be partially clogged from mineral build up over the years. If so, poke them clear using a metal coat hanger.
See post #4 in this thread for a more through explanation:
Toilet flush issue.
HRG
Homerepairguy is offline   Reply With Quote
The Following User Says Thank You to Homerepairguy For This Useful Post:
plummen (04-29-2012)
Old 04-29-2012, 09:21 AM   #3
poor flushing
Done nothing to reduce water volume, did not think about rim holes. Will check. Thanks!
Old 04-29-2012, 07:50 PM   #4
Rewards Points: 582
also check syphon hole in front bottom of commode ..this is a hole that is about 1/2 to 3/4 of and inch gets pluged ....also make sure bowl in filling back to normal height after flushing...
The Following User Says Thank You to ben's plumbing For This Useful Post:
Homerepairguy (04-30-2012)
Old 05-06-2012, 02:49 AM   #5
Since all the toilets have started acting up at once you may have a partial blockage downstream. Does the water kind of sluggishly spin around and not exit the bowl the way it did previously? Do what the other posters suggested first. Hopefully this will resolve your issue.
sanec1 is offline   Reply With Quote
The Following User Says Thank You to sanec1 For This Useful Post:
LateralConcepts (05-09-2012)
Old 05-08-2012, 02:48 PM   #6
Rewards Points: 242
I'd have to second the above. I'd guess it's safe to say that you haven't called a plumber yet...
Ed911 is offline   Reply With Quote
Old 05-09-2012, 02:11 PM   #7
Owner
LateralConcepts's Avatar
I agree with the previous posters as well. If you're suddenly noticing slow flushes in all 3 toilets, that leads me to believe there is some type of blockage in the building drain or building sewer (the 4" line that carries waste from everything in the house to the city sewer or onsite septic system).
Are you on city sewer or septic? If you're on septic, when was the last time you had the tank pumped and inspected?
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Tags
toilet
how do i tell what size "rough in" my current toilet is? liverlipsyyz Plumbing 12 07-20-2012 02:39 PM
Toilet leaks? but not really? gunrock Plumbing 3 04-22-2010 06:20 PM
Bubbles In Toilet Tank JCNimmo Plumbing 2 01-29-2010 09:11 AM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 12:04 PM
Toilet install - 2 questions BataviaJim Plumbing 11 05-11-2009 02:53 PM
