Toilet Replacement: Spinning Bolt - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-05-2012, 08:30 PM   #1
Toilet replacement: Spinning bolt
I'm working on replacing one of the toilets in my house. When trying to remove one of the nuts at the base of the toilet, it's apparently stuck to the bolt and both pieces spin. I could easily cut the bolt off, that isn't the real issue.
The issue is, if I have to cut the bolt out, would it require just a new bolt to be inserted, or would the whole flange need to be replaced as well?
Rufe is offline   Reply With Quote
Old 07-05-2012, 08:40 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
Cut it off and replace both bolts with a new set. Common practie
Old 07-05-2012, 08:45 PM   #3
I was figuring and hoping it would be that easy. I just didn't want to keep running to HD after each step to pick up "just one more thing."
Thanks!
Old 07-05-2012, 09:08 PM   #4
Rewards Points: 334
Thanks!
That's common practice for me.....
tribe_fan is offline   Reply With Quote
Old 07-05-2012, 09:09 PM   #5
the Musigician
DangerMouse's Avatar
Pull the unit before you go to the store. This will save time and gas if you DO need to replace the flange if it's rusted through, broken, etc.
DM
Old 07-05-2012, 11:24 PM   #6
Rewards Points: 13,300
Some wax rings come with new bolts and nuts in the box.
Old 07-06-2012, 10:01 AM   #7
Bill Kearney
Rewards Points: 1,174
Sometimes it's easier to buy more than you need and return it later. Or keep it on-hand for the next job. It's possible the flange is wrecked but you won't know that until you remove the toilet. And there are repair kits that can work around a broken flange, as that's not always an easy thing to fix.
wkearney99 is offline   Reply With Quote
Old 07-07-2012, 09:48 AM   #8
I got the old toilet out and the old flange was just fine. New toilet actually came with bolts, which I didn't see when I first went through the box. Oh well. Everything else went off without a hitch.
The Following User Says Thank You to Rufe For This Useful Post:
TheEplumber (07-07-2012)
New toilet base doesn't line-up to floor bolts wwsteel7 Plumbing 9 11-25-2010 11:02 AM
Toilet leaks? but not really? gunrock Plumbing 3 04-22-2010 06:20 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
Toilet valve replacement? steve771 Plumbing 18 07-10-2007 11:50 AM
