Toilet Replacement Question: - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-04-2010, 10:04 AM   #1
Toilet replacement question:
1958 house, a lot original, some remodeled.
Existing toilet leaking around base. Removed.
Found that the tiile was laid higher than brass flange, which is broken probably due to too much torque on screws. Two wax rings installed to "fix" problem.
Removed everything & cleaned area. Subfloor seems OK, currently drying area with a fan.
1. Best way to raise the new installation a bit so it's higher than the tile and makes for a solid fit?
2. Not sure how to describe this, but I'll try: the drain pipe, or at least the top section of it, seems to be made out of fairly soft "lead" (????) The end was beaten out and around and onto the existing brass flange. It's cracked in a few places, and I can't see what good it's doing. What should I do with this?
TIA!
minneapolis1 is offline   Reply With Quote
Old 02-04-2010, 12:12 PM   #2
Insert catchy title here
AppleMac*Fit's Avatar
Your toilet flange is broken from what you are saying and the floor is now higher around the flange because of tile. Is that correct?
I had the same problem with my bathroom remodel.
You need to install a flange repair ring (Big box store sell those). Here's what they look like. I have a concrete subfloor, so I screwed it into that with concrete screws.
Then instead of a wax ring, I used a newer product that is reusable and is very versatile for heights. It's really cool - it uses an o-ring and a gasket as the two things that seal, and a plastic tube is what helps the height (also available at the big box stores).
And here's a link from another guy showing you how to install (it's easy).
Take care!
AppleMac*Fit is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet flange extension question bob22 Plumbing 3 12-18-2009 06:41 PM
Toilet Plumbing question.. okcjeeper Plumbing 3 11-03-2008 07:36 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
