Toilet Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-18-2007, 12:20 PM   #1
Toilet replacement
Can I replace my four mounting hole toilet with a two holemounting toilet?Please reply asap.:confused::confused:
imported_harryo is offline   Reply With Quote
Old 08-18-2007, 12:28 PM   #2
I whish I could give you a yes or no answer. I have never seen a 4 mount hole toilet. However many of the floor flanges I have seen have 4 mount locations and when the toilet is mounted only two are used. Unless this 4 mount hole toilet uses a special style floor flange I would not expect a problem (no promises here as I said I never saw a four mounting hole toilet). Maybe some other users can shed more light on this one! Good Luck and let us know how it works out
Mgmopar
MgMopar is offline   Reply With Quote
Old 08-18-2007, 12:34 PM   #3
Thank you for your quick reply. only two of the bolts are in the flange the other two just screw into the floor this toilet is around 45-50 years old.maby that's why you've never seen one .
Old 08-19-2007, 06:54 PM   #4
toilet
New toilet installed on 8/18/07 .what a difference in the flush.thanks:D:D
Old 08-30-2007, 03:03 PM   #5
new toilet
I got the toilet replaced now I'm waiting for an estimate on a tub liner & shower wall.one thing leads to the other.:D
Old 10-09-2007, 12:07 PM   #6
bath fitter
I got a very good price from bath fitter and also some good feedback ,they're coming in november.I'll update when job is complete.
Old 11-07-2007, 02:40 PM   #7
bath fitter
New tub liner and shower wall installed really looks great.I would really recommend bath fitters but not if your in a rush.They do the job in a day but it takes several weeks before they start because they must make tub liner so if you don't need the job done yesterday .I also think the price was right.
