Toilet Repair - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-14-2011, 09:40 PM   #1
Rewards Points: 27
Toilet Repair
Can a bolt at the base of the toilet be replaced without removing the toilet? In other words, do they make a type of bolt that can be inserted, twisted into a locking position and tightened?
cm3putter is offline   Reply With Quote
Old 01-14-2011, 10:12 PM   #2
no .
broox is offline   Reply With Quote
Old 01-14-2011, 11:07 PM   #3
Picky Plumber
why do you want to do this?
Plumber26 is offline   Reply With Quote
Old 01-15-2011, 06:08 AM   #4
If the bolt is loose and won't tighten, either the bolt is corroded and no good or the flange is damaged/broken. Both require removal of the toilet to repair properly. It is not a difficult job to remove a toilet. Shut off water, empty tank and bowl of water, remove bolts and water connection, remove toilet. Often the bolts/nuts are frozen and the nut has to be cut off. Always use brass replacement bolts.
Old 01-15-2011, 12:55 PM   #5
whistling toilet tank fill
Hello. Need an expert with toilet fill. My son, non-plumber, replaced my wax ring and says he did not touch anything inside tank, but now my toilet fills quietly at first and before it finishes, it whistles with the rest of the fill. Annoying. I have a 1.6 gallon, super flush, super quiet, standard toilet with flomaster valve, toilet cost about $150.00. Do you have any idea what causes he whistling fill and what adjustment I can make, if any?
Need Advice is offline   Reply With Quote
Old 01-15-2011, 01:02 PM   #6
Are you saying the bolts could cause this problem? I am a lady with no experience with toilets.
Old 01-15-2011, 01:42 PM   #7
Sorry, I'm learning chatroom basics.
I just figured out how to start a thread. Sorry for my thread on your post.
Vitreous china toilet tank repair jjrbus Plumbing 20 10-18-2012 06:00 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Eljer toilet repair KAParrish Plumbing 3 01-29-2010 07:13 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
