Old 03-19-2007, 11:14 AM   #1
toilet related to hot water heater?
So we recently had a new hot water heater put in (Bradford White). While doing laundry my girlfriend noticed some water coming out of the pressure release vent on the side of the heater. We called the guy who put it in and he asked if we recently did any plumbing in the house. Well turns out we had a toilet fixed because we noticed it was running what seemed like all the time. After hearing this the water heater installer said immediatly that t his was the problem. That when we "fixed" the toilet we removed the pressure release mechanism that was in the toilety and that the toilet was supposed to be running like that, and now that it has been removed it will vent out the pressure valve. Does this make sense to anyone? He suggested we get a pressure release tank which I have heard of and do think would work but does his explanation of the toilet seem right to anyone else?
Thanks a lot
Last edited by Ron The Plumber; 03-19-2007 at 08:06 PM. Reason: Remove link to other forum
bwfreas is offline   Reply With Quote
Old 03-21-2007, 04:20 PM   #2
Not unless you have extremely high water pressure. Anything over 80 pounds is high. If what he said was true, the water bills would be really high all over the U.S.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 03-22-2007, 11:16 PM   #3
Jurneyman/Master Plumber
What did you fix on the toilet?
PlumbinginIA is offline   Reply With Quote
Old 03-23-2007, 07:20 AM   #4
Journeyman Plumber
Ron The Plumber's Avatar
Maybe I'm not up to date on new products, but I have not seen or heard of toilet innerds that act as a pressure relief for water heaters
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 03-23-2007, 08:11 AM   #5
Lol, the governor ballcock by Watts. I havent seen one in years. One of Watts dumber ideas but it worked.
Pipes is offline   Reply With Quote
Old 03-28-2007, 12:12 PM   #6
A friend just narrowly missed getting his basement flooded. A year ago he had a new metered water supply installed from the city put into a older home that had previously been on a well. There was never any mention by the contractor or whoever did the work (owner was gone at the time) about any check valve on the new meter. The results of making it a closed system almost created a disaster. Over the year ,intermittenly, there would be high pressure in the lines. The problem finally came to point of creating leaks. After much investigation and questioning he found out about the new meter having a check valve in it, and with the hot water tank building pressure in the now closed system. The owner will insall a small expansion tank in the inlet line to resove the problem. There seems to be a limited knowledge on this. Hope this helps some of the high pressure issues wrote about in this forum. bjr23
bjr23 is offline   Reply With Quote
Old 03-28-2007, 02:45 PM   #7
Diesel Fitter
A governed ballcock, so if your toilet sits idle long enough it will raise your water bill wowee wow wow watts a great idea!
mikemy6 is offline   Reply With Quote
Old 03-28-2007, 08:21 PM   #8
ROFL
That's what we thought around here we pay for water in and out.
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
