Toilet Recommendations? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-06-2013, 06:25 AM   #16
Rewards Points: 2,154
javiles, thanks. When I was property manager I learned how to do a lot of repairs for when my maintenance person was on vacation.
Startingover is offline   Reply With Quote
Old 05-06-2013, 07:31 AM   #17
Had to share this Kohler review which made me laugh.
""This toilet works so well, my neighbor came over with his 85 lb dog , had to use the bathroom and brought his dog in with him. I heard him flush the toilet. When he came out, his dog was gone. Poor Fluffy""
Old 05-06-2013, 07:56 AM   #18
Mike K
Rewards Points: 83
Originally Posted by Javiles View Post
if you home has cast iron 1.6 1.28 is usually not be enough water to get it to its final destination, 90% of our main line clogs are toilet related. Thanks water conservations act.
That's interesting..
I figured if the crap made it out of the toilet, it was gone.. But your saying its not enough water to get it down the pipe and to the city sewer?
rebar is offline   Reply With Quote
The Following User Says Thank You to rebar For This Useful Post:
Startingover (05-06-2013)
Old 05-06-2013, 09:20 AM   #19
Plumber
TheEplumber's Avatar
Rewards Points: 566
Waste lines are sloped at 1/4" per foot- sometimes at 1/8"/ft. This was great when toilets flushed 3 gal. Then the conservationists came along and said 1.6 toilets are now the law of the land. So you've cut the water volume in nearly half- but the pipe is still nearly flat.
Now you have the 1.28 or duel flush toilet- toilet manufacturers are improving the flushing capabilities but the plumbing design has not changed in a long time.
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 05-06-2013, 11:17 AM   #20
747
registered
747's Avatar
Rewards Points: 534
I would think the wash machine would get it out to the main.
747 is offline   Reply With Quote
Old 05-06-2013, 05:48 PM   #21
Rewards Points: 744
Here's 35 pages of real American Standard Champion reviews. Start here: http://www.terrylove.com/forums/show...hampion+review
Seattle2k is offline   Reply With Quote
The Following User Says Thank You to Seattle2k For This Useful Post:
Old 05-06-2013, 07:09 PM   #22
747
registered
747's Avatar
Rewards Points: 534
Terry Love is bought and paid for by Toto. I have the champion 4. No plunger need it doesn't leak. Its a great toilet. Toto did have the corner on the market. Not anymore. Not to mention Toto toilets are EXPENSIVE.
The Following User Says Thank You to 747 For This Useful Post:
Old 05-06-2013, 08:12 PM   #23
Rewards Points: 4,796
Probably the most important attribute for avoiding clogs is a fully glazed trap of larger diameter than 2".
jeffnc is offline   Reply With Quote
Old 05-06-2013, 08:57 PM   #24
Remodeler
Rewards Points: 320
The early american standard champion used a flush tower instead of a flapper. Many of them had problems with the seal on the tower leaking and the tower emitted a somewhat loud thunk as it closed each time the toilet flushed. That said; mine is 10 years old and I have not had a single problem with it. While the clunk is a little annoying in the middle of the night, it flushes extremely well and it does so every time. It flushes even better than the toilet with pressure assist flush in my second bath and it is by far quieter. The pressure flush is very powerful (and very LOUD!), but the bowl has a small trap opening and it still clogs easily.
The new champion 4's use a more common style of flapper, just way over-sized. They have a 2-3/8 trapway and a 4 inch flapper valve, pretty much any toilet with those kind of specs is going to flush extremely well. Couple years ago I put 3 of these in a friends new house and one in his shop and he is extremely happy with them. You could literally throw your plunger away, I can't remember ever having a single clog in the entire 10 years since it was installed.
iamrfixit is online now   Reply With Quote
The Following User Says Thank You to iamrfixit For This Useful Post:
Old 05-06-2013, 09:10 PM   #25
Plumber
Rewards Points: 566
I put 2 Toto Drake duel flush in a church a few months ago. It's an old building with bad water pressure. Bathrooms are small with one toilet each - close to 150 people. Their 3 gpf toilets were clogging and slow to fill- couldn't keep up with the rush hour traffic after services. Haven't received a single complaint since- the plunger has been retired
Another good toilet is made by Vortens- wholesale only
Old 05-06-2013, 09:57 PM   #26
747
registered
747's Avatar
Rewards Points: 534
To the original poster. If your going to buy a Toto. Get a drake gmax flush 1.6 gallon. I"m not sure if they still make the 1.6 it might now be 1.28. I would expect you to pay 300 plus.
Old 05-07-2013, 10:52 AM   #27
I highly recommend American Standard Champion toilets as well.
markx83 is offline   Reply With Quote
The Following User Says Thank You to markx83 For This Useful Post:
Startingover (05-07-2013)
Old 05-07-2013, 11:25 AM   #28
Bill Kearney
Rewards Points: 1,174
More like thanks to the plumbers that did a poor job installing the lines.
wkearney99 is offline   Reply With Quote
The Following User Says Thank You to wkearney99 For This Useful Post:
Toilet Recommendations: Box Store vs. Plumbing Supply Store BBC301 Plumbing 23 11-13-2012 09:40 AM
Recommendations for good performing toilet rightit Plumbing 16 03-10-2012 12:59 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
