Toilet Rebuilding Kit - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-17-2012, 03:27 PM   #1
Toilet rebuilding kit
Some advise on the best rebiuld kits for toilets. I bought a fluidmaster kit and was disappointed with the quality. I bought it from the big box because the supply house was to far...
paintdrying is offline   Reply With Quote
Old 12-17-2012, 03:41 PM   #2
The Fluidmaster "PRO45" (formerly known as the 400A) is actually a very good product.
Ishmael is offline   Reply With Quote
Old 12-17-2012, 04:46 PM   #3
Thanks. I just got off the phone with the supply house and they are saying just go ahead and replace the whole toilet. They will sell me everything, seat ring, line. Elongated bowl. Called a Pelican toilet which I have never heard of. 100 dollars. Or 30 dollars for the rebuild kit. The Gerber Viper is 100 dollars as well. The problem with the toilet I am trying to fix(44 year old American Standard) is that it started filling very slowly for the past two weeks. The fluidmaster in the tank now looks fairly new. The toilet has no shutoff and the gate in the basement is frozen. Can I pull the top off the fliudmaster with the water still on? I am also concerned with the toilet having a 5 gallon tank, and these fluidmasters being set up for smaller sized tanks.
Old 12-18-2012, 12:39 PM   #4
Special User
Rewards Points: 1,230
Gate valve may be the whole problem here. Could be plugged up with deposits and debris.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 12-18-2012, 03:50 PM   #5
I figured I should follow the old saying, if you are going to do a job, do it right, and as efficiently as possible. I shut the water off at the street I cut the gate valve out and sweat a ball valve in. I was going to originally use a sharkbite fitting, but decided to only use it if the valve at the street was leaking. Used a 1/4 turn stop, all bras, real nice. I used a copper supply line up to the tank. I managed to secure the flage where it was solid in the floor, but would of liked to have cut up and retiled the floor. Went with the Gerber Viper toilet. 1.6 gpf. Real power house and nice looking solid toilet. The toilet comes with bolt caps but no bolts, and the wax rings now come with just the ring. No bolts no caps. I paid 105 dollars for the round bowl toilet, I am very happy
Old 12-18-2012, 03:56 PM   #6
Special User
Nice job, thanks for the followup!
Please advise on slow flushing toilet? WillK Plumbing 5 03-12-2012 10:58 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Rebuilding 3 Gallon toilet can I still get parts? twilightcall Plumbing 1 06-14-2008 01:11 PM
