Toilet Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-11-2007, 10:31 PM   #1
carpentry
WNYcarpenter's Avatar
toilet question
Within the last week my I've noticed my toilet running for about 5-10 seconds every 15 minutes or so.
There are no leaks where the tank meets the bowl and the flapper seems to be sealing properly. My first guess is that I'm loosing water from the tank slowly causing the float to drop just enough to refill the tank. Where's the water going?
I should replace everything...the toilet as well
WNYcarpenter is offline   Reply With Quote
Old 07-12-2007, 07:54 AM   #2
RippySkippy's Avatar
There probably is a very small trickle leak into the bowl....Lowes has (had) the free colored tablets you put in the tank to help spot the culprit, they were near the toilet repair stuff. Take a small rag and wipe the flapper and it's seats, there could just be a slight layer of gunk built up there....
Or you could replace the toilet!
RippySkippy is offline   Reply With Quote
Old 07-12-2007, 03:24 PM   #3
Pour a couple cups of coffee (liquid only, no grounds) into the tank. Watch the bowl for a while and if the water changes color, there is a leak in the flapper assembly. Wipe off the bottom of the flapper and the seating surface to get rid of mineral deposits that may have gathered. Next would be replacement of the flapper.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 04:43 PM
moving basement toilet cibula11 Plumbing 10 10-20-2007 02:22 PM
Adding toilet in basement with tile on the floor Kyle Plumbing 6 09-13-2006 09:59 PM
