Toilet Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2011, 12:20 PM   #1
RCDD
Toilet question
Good afternoon, I have just a quick question for you guys. In my kids' bathroom I have noticed that in the bowl of the toilet I have a constant flow of water coming from the underside of the top of the bowl. What in the world could be causing this? Thank you in advance for any input.
dannykapp is offline   Reply With Quote
Old 02-02-2011, 12:24 PM   #2
Lightfoot's Avatar
Rewards Points: 272
The flapper is leaking, replace it. It's the part that opens up in the tank to allow the water to come down.
edit: it also could be the fill valve is set too high allowing water to flow in the pipe. if so, adjust it to shut off just before reaching the top of the pipe (a half inch or so)
Lightfoot is offline   Reply With Quote
Old 02-02-2011, 12:26 PM   #3
RCDD
Thank you for the quick respone. I will replace the flapper.
Old 02-02-2011, 12:45 PM   #4
Retired
Edgar214's Avatar
When I replace a flapper I clean the surface it sits on with a fine scotch-brite. This gives me a clean/smooth surface for a good seal.
Mike
Edgar214 is offline   Reply With Quote
Old 02-02-2011, 08:14 PM   #5
RCDD
Replaced the flapper and is good as new. Thanks for the help.
Old 02-02-2011, 10:00 PM   #6
Rewards Points: 150
If anyone else reads this before jumping to replace... Try to wipe the flapper and where it sitss. Those tablets and cleaners can sometimes leave a film that just needs to be wiped off
Docwhitley is offline   Reply With Quote
Toilet not sitting well.... RickyBobby Plumbing 6 01-24-2011 08:23 PM
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
Toilet backfill after flushing hohadcr Plumbing 6 12-20-2009 04:01 PM
Question about Adding toilet to basement dasaint80 Plumbing 5 05-05-2009 07:27 PM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 04:28 PM
