Toilet Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-29-2008, 12:47 PM   #1
pjm
Toilet Question
I had a problem with my toilet's fill valve (it was spraying water all over the top of the tank and it was running down the sides). I recently replaced it with a fluidmaster 400a, but every once in a while it will start filling the bowl a little bit. I don't think water is leaking, but I can't figure out why it keeps re-filling? Has anyone had this problem and know what might be going on? Any help would be great.
Thanks.
pjm is offline   Reply With Quote
Old 07-29-2008, 01:17 PM   #2
Oldguy
Rehabber's Avatar
The flapper is probably not sealing. Just put in a new flapper
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 07-29-2008, 01:23 PM   #3
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
If you hear the Fluidmaster cycle and the water level in your tank doesn't continue to rise to the top of the overflow tube, it is almost certain that your tank is losing water. This is most likely through the flapper.
One sure way to test this is to put a few drops of regular old food coloring in the tank, let it sit for a few minutes and see if the water in the bowl is colored. If so, replace the flapper.
Beware, some toilets only work right with O.E.M. flappers. Home Depot and Lowe's sell several different flappers. Try to find one that lists your brand toilet specifically.
If you want to save water there is a great alternative to a Fluidmaster that not only helps to conserve water but it actually helps keep tank clean too. It's called a Hydroclean and you can check it out here:
http://www.basicplumbingrepair.com/b...oduct-reviews/
They sell these at Home Depot for about $13. I put one of these in one of my toilets and it really works as claimed.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet install question rolls831 Plumbing 9 07-09-2008 09:00 PM
New Toilet Install Question uokman Plumbing 4 04-23-2008 04:34 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
