Toilet Problems - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-06-2011, 09:29 PM   #1
Toilet problems
I am having a few problems with my toilet and hoping someone can help.
Sometimes the bowl does not fill all the way. And sometimes it does not flush unless you hold down the handle.
Not sure if these problems are related or not.
Thanks alot
Rmudder is offline   Reply With Quote
Old 03-06-2011, 10:12 PM   #2
Rewards Points: 5,336
Thanks alot
The flapper in the tank isn't staying up. If you remove the lid, you'll see the flapper isn't lifting as high as it should. Shorten the chain from the handle to the flapper so there's a small amount of slack and flush the toilet. The flapper should stay up and the water in the bowl should all go down the drain.
You might need to try different settings until it functions correctly.
Ron
Old 03-07-2011, 08:11 AM   #3
I've gotten the flapper to stay up. But now the bowl still doesn't fill all the way still.
Old 03-07-2011, 10:55 AM   #4
There should be a small hose that goes into the filler tube in the tank. Is it there? Is it going into the filler tube?
Ron
Old 03-07-2011, 11:03 AM   #5
I will take a look at this. And post back thanks.
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
toilet and hot water heater problems spokanern Plumbing 5 01-19-2010 01:41 PM
Gurgling sound coming from the base of the toilet YerDugliness Plumbing 1 12-22-2009 08:35 AM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 10:14 AM
Raised toilet flush problems ricgail Plumbing 2 11-17-2006 06:06 PM
