Toilet Problems - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-01-2010, 03:57 PM   #1
Toilet problems
I need some advice pertaining to a plumbling problem that i am having....
mm2blessed is offline   Reply With Quote
Old 08-01-2010, 03:59 PM   #2
Me too, funny coincidence. Care to elaborate?
vintagewolf is offline   Reply With Quote
Old 08-01-2010, 04:08 PM   #3
Everytime i flush my toilet black specks are coming up in the bowl, can you help???
Old 08-01-2010, 04:16 PM   #4
take off the lid on the tank. see if there is debris in the tank. Is so, turn off the supply valve feeding the toilet, flush it to drain the tank and clean it out with a shop-vac and Brillo pad.
Old 08-01-2010, 04:20 PM   #5
Okay i will do that, but how can i prevent this from happening again???
Old 08-01-2010, 04:33 PM   #6
Rewards Points: 150
If you are using the handy toilet bowl cleaners that you drop in the tank there's a good chance that they are harming the inside workings of the tank: A LOT OF MANUFACTORS DO NO ALLOW THEM!
braindead is offline   Reply With Quote
The Following User Says Thank You to braindead For This Useful Post:
LateralConcepts (08-01-2010)
Old 08-01-2010, 04:44 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 452
My first thought reading this thread was that the rubber parts are disolving
Old 08-01-2010, 04:44 PM   #8
Owner
LateralConcepts's Avatar
Exactly! They'll not only corrode and deteriorate all of the plastic and rubber parts; but if you use the kinda that turns the water blue, and you ever have an overflow, it'll stain the heck outta your linoleum, tile, etc.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 08-01-2010, 04:51 PM   #9
Thank you all for your quick responds, however, i do not use the bowl cleaners. The debris that's coming from the master bathroom is now coming through the guest bathroom also. Do you all think this is a septic problem???
Old 08-01-2010, 04:53 PM   #10
I have seen black scaly stuff in toilets before. What is that... mold? anyone..
If your gaskets are getting old you'd be best to replace all the guts IMO.
How old is the toilet?
Old 08-01-2010, 04:56 PM   #11
sounds like it is the water supply. Maybe the city is working on the lines and kicking up dirt.
Old 08-01-2010, 04:56 PM   #12
The house was just built in 2007 and i am the only person to live in it. So the toilet is only like 3 years old....... Somebody help me please
Old 08-01-2010, 05:04 PM   #13
Owner
We need more information. Do you mean it's backing up through the drains or it's coming out when water is running in the bowl?
Lateral
(208) 818-8241
Old 08-01-2010, 05:15 PM   #14
The debri is coming through the water whenever the toilet is flushed.... I can see the debri sitting in the bottom of my tank. It's not a lot, but enough to cause me to pay attention to it.
Old 08-01-2010, 05:22 PM   #15
Plumber
Rewards Points: 452
Sounds like minerals, scale or dirt in your water supply. I bet you'll find some in your faucet aerator too.
Toilet Problems akim1220 Plumbing 6 02-25-2014 06:59 PM
toilet and hot water heater problems spokanern Plumbing 5 01-19-2010 02:41 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet Problems Willie5566 Plumbing 7 07-26-2008 08:42 PM
Raised toilet flush problems ricgail Plumbing 2 11-17-2006 07:06 PM
