Toilet Problems - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-31-2011, 03:29 PM   #1
toilet problems
please help my toilet doesn't flush properly (it's hit and miss). I've tried plunging (an immediate fix) and I've tried a septic treatment (didn't do anything). When the toilet flushes, the tank empties but nothing goes down. Any advice or other ideas that I can do?
Thanks!
KC_14 is offline   Reply With Quote
Old 12-31-2011, 05:13 PM   #2
DIY staff
Rewards Points: 7,174
sounds like the toilet has an obstruction---Get your self a toilet auger and see if that will clear the j bend---
If that doesn't do it---the toilet will need to be pulled and the main line rodded or the toilet checked to see if there is something stuck in the j-bend.
Old 12-31-2011, 06:59 PM   #3
Rewards Points: 582
Thanks!
did you try flushing with a bucket.....how old is it ....can you get a picture of bowl....
Old 12-31-2011, 11:11 PM   #4
the jet hole in the bottom could be blocked or closed off .try flushing with a bucket like ben suggested. i have found the caps from toilet bowl cleaners that hang in the tank come off and get inside the bowl and block the jet hole in the bottom of the bowl. would flush sometimes and other times wouldn't. had the guys on new construction forget to take the bolt covers out of the tank and flushed them down inside the bowl also. if it flushes with a bucket of water then something is obstructing the water between the tank and the bowl.
Old 01-01-2012, 01:05 PM   #5
Thank you for all the help. I was able to use an auger to clear the J pipe. Toilet flushes way better now. But, now I'm noticing that the water in the tank fills slowly. Would this mean I have to change the fill valve?
downstairs toilet now leakiing after replacing upstairs toilet davesj Plumbing 3 12-03-2011 05:03 PM
toilet and hot water heater problems spokanern Plumbing 5 01-19-2010 01:41 PM
Gurgling sound coming from the base of the toilet YerDugliness Plumbing 1 12-22-2009 08:35 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Raised toilet flush problems ricgail Plumbing 2 11-17-2006 06:06 PM
